*) incorporated all the bugfixes since v3.30;
*) port remote-access - added ‘log-file’ property. If value is a non-empty
string, then all data that is read from the port is appended to a file
with that name, regardless of the active remote connection;
*) console - removed ‘/user’ from the output of top level ‘/export’ command,
still can be exported by ‘/user export’;
I noticed that “/interface wireless print advanced” returns the same result as “/interface wireless print”. So some advanced settings (RTS) is not visible from CLI. Maybe there is another way to see the settings in CLI? I am used to ‘print adv’ from wireless-test on 3.x
And it would be better to mention Lua support was removed from 4.RC1 in changelog. I wasted some time checking why Lua is not working (trying to first test the Lua in ROS) until I found a notice on your Wiki
dont know if i am doing something wrong. i was used to “print oid” to get the signal strenght oid in the reg-table
now on rc1 “print oid” shows me the same result as “print” both on reg-table and on system/resources
i just spent about an hour reading up on LUA and now realized it has been removed. Oh well : ) The current scripting language isnt that bad, we just need better serial port and file access.
what wifi card do you use? I haw saw kernel failures on 4.x when we tested some obscure card (included in some older Proxim radios). The card seemed to work with 3.x (now thinking about it I am not sure we used wireless-test in the test) but on 4.0RC1 caused immediate reboot when crad was enabled.
