RouterOS v4 released
ALL RouterOS installations with legitimate RouterOS Keys can now upgrade to v4
xezen, the problem will be fixed in the next RouterOS version with volts.
The question however is: how are you going to determine eligibility for free ROS V5 upgrade for hardware with level 4 lic purchased since current version of ROS is V4. (and perhaps, if it matters hardware still comes with v3 preinstalled)
Is OS version 4.x more CPU intensive then 3.x? On a heavy loaded PPPoE server we have seen an increase in CPU load but we changed out hardware at same time so not sure.
M
others say that v4 is less cpu intensive than v3 =)
i notice this V4 less of CPU process!! cool.. that’s why i love mikrotik :laughing:
v4 ROCKS!@!!
I love MT!!
V4rc was a little shaky but v4 fixed it - yeeehhhaaaahhhh!
Now what about the bios 2.23 I’ve heard rumors about?? and how far back will this upgrade go?? RB112 series??
Thank you - Normis!
Rod
Just an update. I removed and added back the routes and yet the gateway interface option just seems to disappear with time.
I can’t tell you when it vanishes but it does. I will send support a supout but for now it’s back to 3.30 as 4.0 is completely unusable.
btw, Netinstall of v4 still contains ‘MIKROTIK ROUTEROS V3 SOFTWARE ROUTER SYSTEM’ license
isn’t it time to remove version from the license? when v3 was released, there was license about v2 in it ))
I was excited to see the temperature monitoring, and it does work correctly in the terminal.
However I can’t bring up the numbers in SNMP, they just show as zero. Is there another OID to use? I want to add a notification with The Dude for an overtemperature alarm.
we’ll look into this. edit: apparently what you got over SNMP is temperature values for RB230 (old product), SNMP support for PC is not yet made, there are some difficulties with it.
Support has confirmed that this is a bug in winbox and will be fixed in 4.1
I think it only applies to x86.
in Winbox? so, all is working, you just cannot see it in Winbox?
When do we expect v4.1?? Mon or Tuesday?
:slight_smile:)
Rod
Yes that is my experience. Had me fooled for some time, I’ve learnt to trust winbox over the years and never thought to check via ssh or terminal.
How about now. Go check out the download page.
Ok - from rock-an-roll to singin the blues.
I just instructed our engineers to roll back v4.1- to v3.30
We’ve been noticing a ripple across the network and figured v4.1 would fix it - no go.
It would drop 1 on the primaries and 2 on the next tower and 3-10 on the towers and cpes after that.
This started 2weeks ago with the update of v4rc - v4 helped some it seemed and v4.1 didn’t make a difference.
Of course the network slowed to a crawl - and of course the complaints have rolled in.
Here’s hoping v3.30 takes us back.
Rod
thanks for the changes in 4.1 but still testing it as i just loaded it up today will let you know if i pic up any problems
but thanks for the update but at this rate of updating versions we will have to go to 4.100 before we move over to 5
as we cant upgrade ever 48 hours? :laughing: :laughing: :laughing: :laughing:
thansk anyway team
Can you clarify… I have some 2.9.50 installs I tried to upgrade to v4 and I can’t because it tells me so when I try in the log.
Thanks,
Scott
