RouterOS v4
Hi!
Where I can download RouterOS 4 package? I need to update one old router from v3
Tnx!
upgrade directly to v6.32, you don’t need v4
Normis, are you sure even when he could have old license key?
Using netinstall will not need license, in the worst case, he will need to click “update license” or email support for a new type key
That’s it. And maybe he will not realise that if we don’t tell him…
It will say that in the software. There will be a warning popup
Fine. Now he is warned in advance and knows what he should expect…
And normis, one off topic question. Isn’t copying the last post of the thread into your reply something against your forum rules? :slight_smile:
I always do that. It makes it clear who I am responding to.
