*) wireless nv2 - fix stalls on encrypted 11n links using high rates;
*) wireless nv2 - fix encryption related kernel crash;
*) sstp - fixed memory leak;
*) fixed problem - bad boot/kernel crc was reported on powerpc boards
when in fact it was good;
Can you be more specific? I have about 200 rules on my RB800 with L7 connection-mark and jump rules and so on. No problems like RC1. To my knowledge all works.
But it might be as you say only on x86. Uldis said something about content filtering not working. See below
I just tested NetInstall. It formated and installed the setup thing on a USB drive that had older RouterOS on it. After booting this USB drive - Setup did not find any harddrives. And with v3 this works.
I also tested to upgrade RC1 to RC3 in demo mode. In log it states the package was installed. But in fact the process was quick like a flash and when it booted up the version was still RC1 and the package was not installed.
Another thing - there are still problems in /store disk, the reported size sometimes is 0, and after a restart - its ok again.
About 24hrs and I think the memory leak in SSTP may be fixed… Its dropped a little, but that may just be everything “settling in”. Will know in a couple days.
Firewall is working on ppc and mipsbe so far as I can tell. Mangle, marking, filter, nat.
