RouterOS v5rc8
What’s new in 5.0rc8 (2011-Feb-01 14:03):
*) added led trigger - change leds on different events;
*) snmp - restored access to routing tables;
*) snmp - fixed memory leak for OID 1.3.6.1.2.1.25.2;
*) ipsec - added ipv6 support;
*) removed broadcast setting from ip address;
*) radv - fixed problem when wrong link local address was used
to send advertisements on bridge interface;
*) ppp - make IPv6 work again (introduced in v5.0rc7);
*) ppp - fixed problem when user re-authenticated and traffic accounting
included data from previous session;
*) fixed traffic-flow on x86-smp (could stop sending flows);
*) improved usb modem mode switching;
*) kvm - fixed problem when sometimes virtualization detection fails;
*) routing - route with recursive gateway sometimes was not selected as
active, if another inferior route with directly reachable gateway
was present;
*) bgp - removed “interface” property from bgp peer configuration, now
ipv6 link local remote address must be specified using the
“address%interface” notation;
*) added extended ethernet statistics (/interface ethernet print stats) for RB800,RB1000,RB1100,and RB7xx with AR7241 or newer cpu;
*) wireless - improved 11n compatibility;
*) wireless nv2 - added support for station-bridge mode;
*) wireless nv2 - added area support;
*) wireless - added ability to set registration-table comment using RADIUS
attribute;
*) implemented usb power-reset command on RB SXT 5HnD;
http://www.mikrotik.com/download/routeros-ALL-5.0rc8.torrent
Also the #30 newsletter:
http://www.mikrotik.com/download/share/newsletter30.pdf
RB7xx, that hints at new models coming soon :wink:
Or maybe simply RB750, RB750G, RB711 ?
I am ever hopeful for new toys Normis !
Thank you guys for the LED triggers. At last I can remove all previously used and now obsolete scripts.
Let’s see now how this “wireless - improved 11n compatibility” thing works in practice. Still no short GI support, though (bad, bad, bad)! :confused:
Bug: in nv2 mode there is not traffic in station (not wds) to bridge or ap-bridge. In station wds to bridge+wds it’s ok, but i don’t need wds in my scenario. Downgrade to rc7.
Looks like IP6 is anywhere :slight_smile:
[admin@demo2.mt.lv] > /system ssh some.internet.site.name user=root
while resolving ip6: could not get answer from dns server
BUG?
Winbox (demo2.mt.lv):
PPP->Interface->PPP Scaner
“By default” shows interface “unknown”[/quote]
Still getting the Ethernet port flapping issue on RB750 :frowning:
Can you guys confirm if this is software or hardware yet?
*) *) added extended ethernet statistics (/interface ethernet print stats) for RB800,RB1000,RB1100,RB1200 and RB7xx with AR7241 or newer cpu;
What is RB1200? Thanks
where did you get that?
it’s an unreleased product codename, it was not supposed to be released.
The first version of changelog
http://www.mikrotik.com/download/CHANGELOG_5
before it was modified
you are very quick. it was modified not more than 30 seconds after release.
Sometimes it’s good to be quick. We are looking for a new product :wink: :wink:
what kernel version have rc8?
kernel version has no changes.
no change from 2.6.37?
“no” usually means “no” :slight_smile:
please tell us more what traffic you don’t see.
uldis please see Ticket#2011020366000114
The traffic in vpls RouterOS v5rc8 doesn’t go, in v5rc7 all is good…
