normis
February 10, 2011, 11:19am
1
What’s new in 5.0rc9 (2011-Feb-09 13:57):
*) wireless - fixed disconnect problem on long distance
802.11 40MHz links;
*) wireless nv2 - fixed station mode that broke when station-bridge
was introduced
*) wireless - more improvements for 11n compatibility;
*) kvm - fix guest starting;
http://www.mikrotik.com/download.html
struck
February 10, 2011, 12:17pm
2
About my previous post from 5.0 rc8 … The ROS with level 6 only supported 1500 concurrent PPPoE connections… why? Regards,
normis
February 10, 2011, 12:20pm
3
It’s possible that your hardware is not powerful enough. We have not heard such reports before
struck
February 10, 2011, 12:23pm
4
Server Dell R410 with two processors Xeon quad-core 2.4Ghz (16 cores) with 32GB RAM DDR3… it is not powerful?
normis
5
what happens when you have 1500 connected, and 1501 tries to connect ?
struck
February 10, 2011, 12:26pm
6
1500 connects. From 1501 only appears in the log: PPPoE connection established from (MAC).
routerboard upgrade doesn’t work v5rc9
[admin@home] > system routerboard upgrade
Do you really want to upgrade firmware? [y/n]
y
firmware upgraded successfully, please reboot for changes to take effect!
< … reboot … >
[admin@home] > system routerboard print
routerboard: yes
model: “750”
current-firmware: “2.28”
upgrade-firmware: “2.32”
normis
February 10, 2011, 12:36pm
8
did you send supout.rif file to support? what is the ticket number, I will check status. We need the file from the moment when 1501 connects. Preferrably with PPP debug logs enabled
m4rk0
February 10, 2011, 12:37pm
10
I’ve just installed 5.0rc9 and under “Files” [Restore] button is missing…
normis:
worked for me.
[admin@home] /system routerboard> print
routerboard: yes
model: “750”
[admin@home] /system routerboard> upgrade
y
routerboard: yes
model: “750”
current-firmware: “2.32”
<… few minutes passed … >
routerboard: yes
model: “750”
current-firmware: “”
<… some more minutes passed … >
routerboard: yes
model: “750”
If I reboot the device I get 2.28 running on it.
struck
February 10, 2011, 1:28pm
13
[Ticket#2011021066000502]
regards,
A question about v5 features (btw I personally like the burst for PCQ and the gre for cisco compatibility):
In an article posted by Mikrotik (I do not have the link) it said that RouterOS supports 200 networks or aggregates in bgp announcement. Will this limitation be removed?
normis
February 10, 2011, 1:56pm
15
mihaimikrotik:
I don’t know any such limits, where did you read it ?
exe
February 10, 2011, 2:01pm
16
Struck,
Do you have problems with RX Drops like here: http://forum.mikrotik.com/t/rx-drops/34593/1
with that machine with 16 cores and 1500 PPPoE users?
16 real cores on 8 real cores with HT??? if 8 go to the BIOS and disable HT, RouterOS benefit more on that. Did you made your IRQ management?
exe
February 10, 2011, 2:14pm
18
Yes it is better to disable HT, specially regarding rx drops.
Maybe 5.0 rc8 or rc9 can make better use of all cores ? Struck ?
IPSEC still no worky on RB1100. Works on RC7, but not 8 and 9. Doesnt matter really. Im sending it back.
struck
February 10, 2011, 2:17pm
20
I have no problem with RX drops on this machine, only PPPoE problems…
