routeros v5x bug - command find script unstable
the find command in scripts used in mk is very unstable in version 5x, please check it … at least on x86 multi-core router…
what do you mean by unstable :slight_smile: ?
I run the script several times to test it sometimes crashes and the debug I did the script hangs at several different points, and that these points have in common is the find command to locate a rule in the firewall and enable or disable basically it. ..
