hotspot redirect doesn’t work correctly after radious login with 6.0 final. (you are logged in but nothing appen)
Works correctly with 6.0rc13.
Please fix bug.
Thank you.
Leo
Please fix bug.
Thank you.
Leo
Redirection still works for me … I’m using external hosted site though, so it might be different from your setup, but I believe all the redirection code is on the AP.
exactly…i have the login website internal to my hotspot with an external radius database.
After login ok from radius its should go to second welcome page (internal) then to an other welcome page (external, www.sdfsdfsdsdfsdf.com)
Its block itself before second page.
With 5.x and until 6.x rcX all ok. Since 6.0 final doesn’t work anymore.
Leo
please contact support@mikrotik.com to get a test release of RouterOS v6.1rc1 which has a fix for this problem.
problem fixed thank you
