RouterOS v6.0rc13 released
What’s new in 6.0rc13 (2013-Apr-08 14:25):
*) pppoe, l2tp, pptp server - increased lcp retransmit count to 10;
*) pptp, l2tp & pppoe clients - added ability to specify keepalive timeout;
*) graphing - fixed problem were interface graphs are lost on reboot;
*) dhcpv6 - added relay;
*) sstp server - restore (disabled in rc12) test mode which allows
running server without certificate;
*) lcd - added option for turning backlight on/off;
*) bgp - fix med comparison check if routes are received from iBGP peer;
*) fixed simple queues - sometimes some simple queues did not limit traffic
(bug introduced in 6.0rc12);
*) allow to change arp timeout (in /ip settings);
*) added /ip neighbor discovery settings setting “default-for-dynamic” to control
discovery on new dynamic interfaces (off by default);
http://www.mikrotik.com/download
Does TX drops already solved on vlans?
IPSEC connections are failing between an RB750GL and an RB2011 after upgrading both to rc13 from rc12. The connections never complete and the log slowly becomes filled with
ipsec, warning, critical
::ffff:0.0.0.0 address relase to pool failed: ERROR_BROKEN: Used has no usedaddr entry (6)
Dear Normis!
Multicast routing (PIM-SM) same source (IPTV channel) with different client IP (Set Top Box) not working in CCR1036 (RC6,RC7,RC8,RC9,RC10,RC11,RC12,RC13). Same ROS version (RC6,RC7,RC8,RC9,RC10,RC11,RC12,RC13) and same configuration (1. RP, 3. Interface) working correctly in RB2011.
Please investigate this problem…
Thx.
Attila
In the attachment screen that shows voltage indicator in the version 6r13 on RB2011UAS-2HnD-IN. Voltage allegedly jumps from <1v to> 60v. The device is stable. Power supply original.
Thank You very much. :smiley:
I’ve already created my script - works fine.
How can it be stable if is an RC release? :laughing:
If it’s a RC or beta - then you probably should test it on your setup in test environment, and only after week or month of testing you can decide whether to put it into production or to wait for the next RC or release. That’s a good practice when you need the new version’s features.
I have 6.0RC6 working fine on my setup in production system (it’s not indicate that yours setup will be fine too).
I’m curious about this as well. Seeing this on CCR1036-12G-4S, about 30 VLANs on Ether1, and no VLANs on Ether2. Been seeing TX Drops on both Ether1 and Ether2, as well as most of the VLANs on Ether1.
Hello, in versions v6rc12 and v6rc13 stop working a script that I have to send me an email backup, any suggestions? The script is as follows
/system backup save name=([/system identity get name] . “-” .
[:pick [/system clock get date] 7 11] . [:pick [/system clock get date] 0 3] . [:pick [/system clock get date] 4 6]); :delay 10;
/tool e-mail send tls=yes to=“mymail@gmail.com” subject=([/system identity get name] . " Backup " .
[/system clock get date]) file=([/system identity get name] . “-” . [:pick [/system clock get date] 7 11] .
[:pick [/system clock get date] 0 3] . [:pick [/system clock get date] 4 6] . “.backup”); :delay 10;
/file rem [/file find name=([/system identity get name] . “-” . [:pick [/system clock get date] 7 11] .
[:pick [/system clock get date] 0 3] . [:pick [/system clock get date] 4 6] . “.backup”)];
:log info ("System Backup emailed at " . [/sys cl get time] . " " . [/sys cl get date])
I also observe that the Health reports widely changing voltages from 1 volt to 70 volts. In RC7 the voltage was reported as 23.9 volts all the time. Also RC13 is not reporting the temperature, which RC7 was reporting as about 30 deg C.
I’m using an RB2011UAS-2Hnd board.
I’m having problems with the Queues.
After a few hours, Winbox doesn’t show the simple queues or queue tree rules. If I print by Console, they are all there.
Did it happen to anyone?
Winbox close when click on log.
rb750g
like any other v6 on x86 when you change eth (82574L) name or queue type the router loose all the vrrp interface and became instable and need a reboot.
If the changes are made on interfaces without traffic the problem doesn’t happen. It seem related to some interroupt problem.
regards
ros
tcpSYNcokies “enable” 100mbit (syn flood , spoof ips) down mikrotik (cpu %100)
if it is CCR, you could not be suprised because it still doesn support multi-cpu on firewall.
If it is a powerfull x86 it could be a problem.
We have upgraded several x86 routers from rc11 to rc13 and we see a notable cpu increase.
regards
ros
6.0rc13 - ARP replay-only on VLAN does not work
Dear Sergejs…
the mac-telnet via the wlan1 problem still not solve with this version…
my hotspot does not work after the update, I can go back to version 5.24, use a rb 1100ahx2
My hotspot works fine on 2011..
