RouterOS v6.27 released
What’s new in 6.27 (2015-Feb-11 13:24):
*) console - added ‘comment’ parameter for ‘/system script’
*) api - return sentences can have property “.section” that groups values
from commands such as “monitor”, “traceroute”,
“print” (with non-zero ‘interval’ value);
*) cloud - add time zone detection feature “/system clock time-zone-autodetect”;
*) cloud - rename “/ip cloud enabled” to “/ip cloud ddns-enabled”;
*) cloud - make “/ip cloud update-time” independent from “/ip cloud ddns-enabled”
*) cloud - when setting “/ip cloud ddns-enabled” to “no” router will send
message to server to disable DNS name for this routerboard;
*) cloud - “/ip cloud force-update” command now will work also when
“/ip cloud ddns-enabled = no”. usefull if user wants to disable DDNS;
*) RB4xxGL - improved ethernet throughput (less dropped packets);
*) RouterBOARD - fixed health reporting;
*) check-installation: fixed wrong kernel crc on powerpc boards
*) watchdog: fix software watchdog for x86
*) ssh - check conn state before sending disconnect message;
*) ipsec - fixed crash that happened in specific situation;
In what specific situation?
I try to setup an IPSec IPv4-over-IPv6 VPN between Mikrotik and Juniper ScreenOS.
The Mikrotik Device crashes when trying to establish Phase 2.
Oh. This was unexpectedly fast release.
Again the same after upgrade from 6.26 to 6.27 DHCP doesn’t work.
Normis,
what about Ticket#2014122166000217
(When the number of PPPoE sessions on the device becomes more 1000 - when you turn off the one PPPoE session on all other sessions observed packet loss)
thanks
Ros
Please make a support output file when you see this problem and report to support@mikrotik.com
RouterOS auto upgrade script is broken, there is no more “current-version” and “latest-version” properties in “/system package update”.
Also if you issue “/system package check-for-updates without-paging” output will never stop.
If you issue “/system package update check-for-updates without-paging once” the output is this:
current-version: 6.27
status: resolving upgrade.mikrotik.com
Hello community,
results after quick test:
  1. SSTP stop working
  • RB (RB2011UAS-2HnD, firmware 3.19) is not able to connect to SSTP server 6.25 (RB750)
  • SSTP clients 6.25 (RB750, RB951-2n) are not able to connect to 6.27 SSTP server (RB2011UAS-2HnD)
  • in /tool profile there are CPU peaks (80%) for “ssl”, in time-period 10s the peaks are 2-3 times for around 1s (probably SSTP client attempts to connect)
  • after downgrade to 6.25 everything is working fine
  1. Set script variable via SMS
I didn’t even know monitor-traffic could monitor multiple interfaces at once… Awesome! Big win for API application efficiency here :smiley: .
Already done.
is ether1 in the bridge?? if yes you need to move DHCP to Bridge, it doesn’t work on bridge ports.
Before (RouterOS v5 ) it was invisibly moved to master bridge interface anyways.
But “comment error” like in firewall would be nice any ways :wink:
Sounds like you have DNS/connection problems, i am upgrading all boards like that since this feature came out.
But i have also observed that check-for-update, if unsuccessful, never stops, it will try until successful…
FYI v6.25 was the problematic version for me. I even reported that to support. I was fixed in v6.26
Make sure that you have both ends of the tunnel with latest version.
I just upgraded both ends of my SSTP tunnels tp 6.27 - all is working as expected
Yes you are right but, but it was not enough to switch to the bridge.
I had to delete the bridge and re-create it then it worked.
Thank you.
system health does not work..
@macgaiver:
Thank you for hint, upgrade of both ends fixed the issue :slight_smile:
I was doing just a quick test so I have not tried this option and also I didn’t have any issues with SSTP in 6.25 .
/system health print
This works for me on RB2011, ROS6.27, latest firmware.
It is NOT bug. What do you want to see in system health?
RB951 don´t have voltage monitor and don´t have temperature monitor. http://routerboard.com/RB951G-2HnD
doh! im sorry, my false!
Holy schnikes, 6.26 just came out last week!
How does this work exactly? IP address geolocation? The accuracy of that can be hit-and-miss. If it detects the wrong timezone, I assume we just report this to support?
– Nathan
It is true. Mikrotik Support is there any known serious problem in 6.26?
