*) email - increase server greeting timeout to 60s;
*) lte - ZTE MF823 may loose configuration;
*) userman - update paypal root certificate;
*) timezone - updated timezone information to 2015b release;
*) cm2 - fixed capsman v2 100% CPU and other stability improvements;
*) route - using ldp could cause connected routes with
invalid interface nexthop;
*) added support for SiS 190/191 PCI Ethernet adapter;
*) made metarouter work on boards with 802.11ac support or usb LTE;
*) sstp server - allow ADH only when no certificate set;
*) make fat32 disk formatting support disks bigger than 134GiB;
*) fixed tunnels - could crash when clamp-tcp-mss was enabled;
*) added basic counters for ipv4/bridge fast path, also show status wether fast
path is active at all;
*) trafflow: - fixed crash on disable;
*) pppoe over eoip - fixed crash with large packets;
*) tilegx - fixed memory leak when queue settings are changed;
*) ar9888 - fixed crash when hw reports invalid rate;
*) console - fixed “in” operator in console;
*) console - make “/system package update print” work again.
*) tile - rare situation when CCR devices failed to auto-negotiate ethernet link (introduced in v6.25);
*) dhcpv4 client - it is now possible to unset default clientid and hostname options
*) initial RoMon (Router Management Overlay Network) support added.
Can we please continue to have torrent link for all packages in one hit? I like to keep them organised for offline use in case out in the field - nice to have both ‘all packages’ and the upgrade package and extra packages, rather than going through and clicking them all and organising them again.
joegoldman - At the moment we are not offering torrent any more. You can write script which will download files as you like and use it after that for each new version. File names always stay the same.
We do not offer torrent download directly from our servers any more. You can download this torrent, download RouterOS files, associate them and then share with others.
If problem still persist, then make sure that you use latest firmware. Run command “/system routerboard print” and if latest-firmware is higher than current one then run commands:
“/system routerboard upgrade” and “/system reboot”
cegner - I see that leds on SFP 10-12 are on when there is nothing connected to them but are they working as suspected and only problem is leds? Please add description to your picture in order to get more precise and useful reply.
Sorry for not beeing precise. LEDs of ports sfp10 to sfp12 show activity although nothing is connected. Ports are working.
It’s a new box upgraded from 6.18 to 6.28. Seems there’s an error in default config:
/system leds
set 0 interface=sfp1
set 1 interface=sfp2
set 2 interface=sfp3
set 3 interface=sfp4
set 4 interface=sfp5
set 5 interface=sfp6
set 6 interface=sfp7
set 7 interface=sfp8
set 8 interface=sfp9
set 9 interface=sfp1
set 10 interface=sfp1
set 11 interface=sfp1
set 12 interface=sfpplus1
set 13 interface=sfpplus1
As i understand, 2014122166000217 not fixed in this release.
If this is not a military secret - when can be expected fix of this error?
For me - it’s very serious and annoying bug and my customers eating my brain.
I tried to update my router, which had ospf, and it totally went crazy, till i returned to 6.37, not sure what happened to this CCR, but careful while upgrading. i was interested in the route fix. !
