RouterOS v6.6 released
The screenshot is showing an x86 machine. We have received unm’s Supout.rif file, and we are looking into it
Thanks very much, problem is still active for as. This router used for PPPoE server (appr 1500 clients, 250Mb traffic max). Queue standard(dynamic pppoe queue simple) and queue tree use(firewall traffic mark and queue tree), thas all.
Support has answered your ticket. The issue is fixed in v6.6 already.
I have also reproduced issue 1. I tried to upgrade one of the my x96 router (5.26) to v6.6 but I observed very high latencies. Then I tried to change the ethernet speed with the same result than adrijco. I solved the problem swaping the application of the network cards (Driver compatibility?)
Also, I have observed how sometimes the router hang up when I changed the ethernet speed. Winbox connection freezed and the system wasn’t able to reboot. I have to disconnect the router.
Issues found in 6.6:
When using ipv6 over pppoe, my NAS got 50% CPU to dhcp (x86). Profile showing dhcp using 50% CPU. usualy the box use 6-9% CPU.
Upgrade make all packages activated, eg wireless package on rb1100
CA certificate error (I dont use CA)
Something happend to my l2tp “terminator”. Clients did not get a sucsesfull login. Downgraded to 6.5.
Anyone with NTP synchronisation issues, could you please email support with your supout.rif file ? Thanks!
Where is my posts? Why mikrotik deleted my post, what contains the real things about mikrotiks update habit?
I wrote to support, but no answer.
Ticket#2013111166000632
Please follow our forum posting guidelines, and we will not have to remove your posts:
http://forum.mikrotik.com/faq.php
This is a community forum, and your personal requests towards MikroTik management, should be sent to our E-mail, not to our forum users.
thanks for sharing in valuable info.
Was posting my issue here (http://forum.mikrotik.com/t/high-traffic-i-e-file-transfer-network-lost/71427/1), care to give some help if this is some VLAN issue on the FW?
thank you for your post.
Did you upgrade to the final release, the one from our webpage? We can’t repeat the problem, we can change names just fine. Maybe you are running a pre-release v6.6?
Welcome. May I know is this a bug that going to be fix on next release?
VLANs have problems in v6.6, this is known, and v6.7 will have this fixed. We will release the new version today or tomorrow.
Normis, dont forget about this too: http://forum.mikrotik.com/t/routeros-v6-6-released/71356/94 :smiley:
As I already asked you in the other topic, please check if your timezone is also correct in the “/system clock” menu. Your RouterOS system time should also match the same settings.
As i said many times, it is correctly set always…
/system clock> pr
time: 15:36:18
date: nov/13/2013
time-zone-name: Asia/Jakarta
gmt-offset: +07:00
What’s new in 6.7rc1 (2013-Nov-11 15:04):
*) fixed hairpin nat on bridge with use-ip-firewall=yes;
*) fixed vlan on bridge after reboot having 00:00:00:00:00:00 mac address;
RB2011 6.6
Ntp client shows stopped in WinBox even though enabled
CLI indicates its synced and shows date/time correctly
apparently this required a reboot to clear it up
RB2011 6.6
DNS Static change bug
removing a static dns name does not remove it from cache even after a flush, only way to clear is a reboot
