RouterOS v6rc10 pre-released
What’s new in 6.0rc10 (2013-Feb-15 10:47):
HotSpot server requires “address-list” configured to work properly
*) ppp - added bridge-path-cost & bridge-port-priority to ppp profiles;
*) ppp - made RSTP work over ppp links as well;
*) ppp - added last-logged-out to ppp secrets;
*) ppp - made MRRU work propererly on CCR;
*) hotspot, ppp - support multiple address-lists;
*) fixed problem - could not format disks larger than 2Gb on CCR;
*) fixed problem - repartitioning flash second time made system unbootable;
*) fixed problem - partition fall back settings got corrupted;
*) fixed problem - package made for other architectures could be installed,
making whole system non functioning;
*) sstp, ipsec - respect CRLs;
*) certificates - for certificates marked as trusted=yes,
CRL will be automaticly updated once in hour from http sources;
*) fixed ppp family interfaces - show it’s status (bug introduced in rc8);
*) fixed p2p, connection-bytes firewall matcher;
*) fixed ip firewall nat action=same;
Upgrade includes several stability improvements for Cloud Core Routers.
http://www.mikrotik.com/download
congratulations for the people of mikrotik.
You guys always bring improvements to routeros, a sign that you mean it with us
Thank you for your efforts, I appreciate that
wow! AFAIR, I was talking about this on some EU MUM in '10 or '11 - it’s time to pack up my back pack for Zagreb and generate new ideas :smiley:
how should RADIUS send several address-lists to the router? as separate value pairs of the same name?
warning on download page: Hotspot not working
RB433UAH (power 24V 2A)
RouterOS + MetaROUTER (opendchub,web server) > uptime 3h KO!,destroy,broken,died, no work proxy, >> reboot OK
Is it a bug in RC10 or hotspot is not implemented in v.6 RC at all? I’ve started to upgrade routers from 5.x to 6rc9 except those with hotspot function. I had a plan to upgrade them with 6rc10, but now I see that will not work.
I thing it is bug in rc10. In rc9 hotspot works
What is the option of multiple address-lists in hotspot and ppp? How can it be used?
I thought that the p2p matcher was somehow abandoned since the complicated nature of nowadays p2p clients.
What has been improved in here? (I doubt encrypted p2p connections are matched)
This is what I get after performing upgrade on my RB493G:
[admin@MikroTik] /ip service> print
 #   NAME                                      PORT ADDRESS        CERTIFICATE
 0   telnet                                      23
 1   ftp                                         21
 2 X www                                         80
 3 I ssh                                         22
 4 X www-ssl                                    443        none
 5 X api                                       8728
 6 I winbox                                    8291
[admin@MikroTik] /ip service> enable www
error - contact MikroTik support and send a supout file (2)
[admin@MikroTik] /ip service> enable winbox
I cannot connect to the services that are marked invalid.
now pre-relased ??
it was “relased” a fer hours ago.
mikrotik ?
I need help, I need the quues tree functions, global out, and in global, and global total, however do not have the RC9?, in version 5.22 has my works normal full cache without them without full cache.
but where is the 6rc10 files in the download page?
There is only main package (.npk) now, marked as “pre-release”. It seems like RC10 was canceled because of some issues, so we should wait.
I’ve upgraded my RB493G without any problems, maybe I’m lucky one :slight_smile:
http://www.mikrotik.com/download - bottom of page
to MT:
Just wondering … how many rc versions can we expect before final 6.0 comes out? 10? 20? 30? … is there any timeline by when final version should be released or will this rcXX go on and on and on and on and on and on and on …
yes, I could be described as impatient but anyway… keep up the good work adding new features (EIGRP please) and removing the bugs from ROS 5 and 6.
Got a link for that boot file again? Haven’t put it on yet. Ta.
Great, checking CRL was a must that many of us were waiting for.
for example, you set some general traffic limit for all clients, but few of them are allowed/disallowed to use some resources - and you set it via one more address list
in v6, there’s only ‘global’ parent, use it (they said, it was ‘global-total’ in v5, but, as far as I remember, there were some corrections later, so probably now it’s what was ‘global-out’ previously)
help check
@rafaeltdk
http://wiki.mikrotik.com/wiki/Packet_Flow#Changes_in_RouterOS_v6
HTH,
