RouterOS v6rc11
What’s new in 6.0rc11 (2013-Feb-22 09:17):
*) ppp - made MPPE encryption work on tilera;
*) sstp server - added option to force AES encryption;
*) fixed router crash on heavy traffic with sierra lte modem on boards with 32MB RAM;
Also various CCR improvements
http://www.mikrotik.com/download
Has there been at least some testing on the existing openvpn functionality ? It was completely broken in rc10.
Looks like you find more problem.
Test yourself RC11 (think its better then RC10).
Nothing about Hotspot in the changelog. Does it work again?
yes of course, this was the main reason for release. rc10 was recalled, and this is an upgrade to rc9 (rc9 → rc11).
any possibility to see MLPPPoE server in v6?
regards
Ros
So your main reason for releasing an upgrade, is not listed in a changelog? :open_mouth: You may just as well stop producing changelogs completely then…
Still waiting for the vrf fix so its possible to implement v6x to core routers.
+1
The bugs with VRF’s have been holding us back for over a year now.
In RC10 and RC11 I can’t rename or delete SSTP Server Interface. Winbox said “Feature is not implemented”,
terminal said: error - contact MikroTik support and send a supout file (3).
What are those “various CCR improvements” ?
Please list the the things improved and/or fixed. We have 3xCCRs in operation and I would like to know.
RB450G at both ends of a BCP-over-PPTP link.
The Server end of the PPTP link is on 5.23.
Client end of link was updated from 6.0rc9 to 6.0rc11.
After this update, the BCP bridge would not work: at the SERVER end, the BCP bridge port status was stuck on Forwarding:No, with Learning:No flashing to Learning:Yes occasionally, but reverting immediately to Learning:No.
On reverting the client to 6.0rc9, the BCP bridge functioned again.
On upgrading a second time to 6.0rc11, the BCP bridge failed again.
On reverting a second time to 6.06c9, the BCP bridge functioned again.
Supout.rif files have been sent to Support.
I’m sorry, but I have to answer no, this is not working.
HotSpot tuned again, but to no avail.
Works, but if you remove the settings
/ ip hotspot edit hotspot1 address-pool none
and
/ ip hotspot user profile edit no_limits address-pool none
Then the rules are working.
Although I did not have to do that.
This
best router, already made ​​by mikrotik, however the software needs of over one year at least, to be good.
I have configured interface and resources graphs, both to be stored on disk.
After reset only resources graphs remain, interface graphs are lost and started again, like in the case when they are stored on ram.
i have checked both 6.0rc9 and 6.0rc11.
It was ok in 5.23.
Same here. Interface graphs lost after reboot. SNTP set and working.
Intervall is 1Hour.
I just want to report that 6to4 tunnel is now working! :slight_smile: It works perfectly with ROS v5.xx and now with v6rc11 it works too. Previous rc versions didn’t work at all with my RB2011UAS-2HnD-IN…
Your hardware is great, guys. But there is a lot to do with your software. :wink:
+1 i thing the same …
I have 4 CCR 6RC11 the core VRF with no problems.
What you guys been experiencing problems?
