RouterOS v6rc12
What’s new in 6.0rc12 (2013-Mar-26 17:18):
*) ospf - add use-dn option;
*) ospf - fix route-tag handling;
*) fixed layer7 matcher - it is case insensitive now;
*) remote logging - added iso8601 time format support;
*) bgp - change MED propagation logic, now discarded when sending route with
non-empty AS_PATH to an external peer;
*) fixed occasional nand corruption on CCR;
*) ipsec - added ipv4 mode-cfg support for responder;
*) ipsec - fixed some issues with removal of dynamic policies;
*) email - renamed parameter tls to start-tls for send command;
*) wireless - update required when using small width channel RB2011 RB9xx
caveat: update remote end/s before updating AP as both side are required to use new/same version for a link
*) ipsec - generate-policy now can have port-strict value which will use port from peer’s proposal
when generating policy or port-override which will always generate policy for any port;
*) ipsec - responder side now uses initiator exchange type for peer config selection;
*) lcd - changed All interface stat screen (bar graphs) to show total bandwidth usage, combine rx/tx together;
*) lcd - removed “all-interface-mode” option;
*) lcd - changed “Interfaces” screen to show interface usage similiar to All interface stat screen;
*) lcd - improved Interfaces → * → Info screen, added more wireless information;
*) lcd - added Registration Table screen for wireless interfaces under
Interfaces → ‘wireless interface’ → Registration Table;
*) fixed occasional kernel crashes on CCR;
*) fixed other than only-hardware-queue interface queues on CCR;
*) lte - devices with vendor/product id pair 0x0f3d/0x68AA now uses directip inferface;
*) dhcp client v4 - option add-default-route now supports special-classless value;
*) significantly increased simple queue performance on multi core systems (up to 9x on CCR1036 with at least 32 top level simple queues)
*) ip arp - new property published;
*) web proxy - added new option max-cache-object-size,
upper limit of max-client-connections and max-server-connections is now calculated from system RAM;
*) ospf - fixed inconsistency in external ECMP route calculation;
*) certificates - CA keys are no more cached, every CA operations now requires a valid CA passphrase.
use set-ca-passphrase for scep server to cache CA key in encrypted form;
*) ppp - made MPPE encryption work on tilera (bug introduced in 6.0rc10);
*) tool fetch - https support with optional certificate verification;
*) sstp server - removed test mode which allowed running server without certificate;
*) trafficgen - add support for ipv6 header;
*) wireless - added support for small channels on SXT lite;
http://www.mikrotik.com/download
“System package → Upgrade” is also live now!
Morning,
After upgrade one x86 system with v6rc12 it creates a file named um-before-migration.tar with 2 files inside: logsql.umb and mainsql.umb. Just delete it?
If you don’t need these backup files, just delete. They are User Manager database backups
Hello
IP>>HotSpot>>Active Users>> Users Tx Rate , is not active on this Version.
It was not active on RC11 also.
Any suggestion ?
Regards
Do you use Bridge ?
No !
In fact it shows zero for all active Hotspot users Tx Rate
On rc12 (build from 26/Mar ~17) on RB2011 there is a problem with Graphing of interfaces..
When I reboot router the statistics of interfaces is deleting..
THe CPU, HDD, Memory its ok..
A`m testing on 1036 the last build and there is everything ok..
second bug RB 2011
Lcd is not working (touchscreen too)
works on our RB2011, maybe some coincidence. try “/lcd set enabled=no” and then back to “yes”. also try recalibrate command. Did you reboot?
Yes I try everything.. on rc11 works fine.. on rc 12 build from 20 mar works fine too)
And what about the graphics?
can you send your supout.rif file to support@mikrotik.com ? make sure you are running the rc12 release from our webpage, not from the test link.
is the issue resolved as i got the same issue on rc 11
http://forum.mikrotik.com/t/rc11-hotspot-accounting-problem/64726/1
Normis/MRZ/Mikrotik crew. I don’t know how often this is said but I’m thankful to see that yalls are working your butts off to make this a better product. While I think that there’s a lot of frustration that can be seen and is expressed, I still think it’s a great product and I plan on buying more of it in the future (money permitting as always). So as always, thank you :slight_smile:
My RB951G reboots ever 20-30 s after upgrade from 6.0rc11 to 6.0rc12. No winbox connect
Did you check for any supout.rif files?
In v6rc12 it is not possible to assign LCD to LEDs:
This was possible and was working fine in v6rc9:
Device: RB2011UAS-2HnD-IN
Device has been “netinstalled”. All files destroyed :frowning:
Another micro-bug:
In WebFig, clicking [Hide Menu] always loads Quick Set.
because quues not updating this rate avg rx and tx, online? very slow.
It was a bug and was fixed. Obviously, the LCD is not a LED.
