RouterOS v7.0beta4 and MC7304
I try v7.0beta4 witn Sierra Wireless MC7304 but it still at PPP mode not LTE.
This is oposite howto, from default lte to ppp mode: http://forum.mikrotik.com/t/sierra-mc7430-4g-lte-a-mini-pci-e-modem-ppp-issues/99391/39
You should check the directip settings, the usb type-mode and internal at command to work with LTE mode and have latest modem firmware (not MikroTik).
You read the : https://wiki.mikrotik.com/wiki/Manual:Peripherals notes to your modem?
For switch from PPP to LTE mode, you need switching to MBIM:
/interface ppp-client at-chat ppp-out1 input=“AT!ENTERCND="A710"”
/interface ppp-client at-chat ppp-out1 input=“AT!UDUSBCOMP=8”
/interface ppp-client at-chat ppp-out1 input=“AT!RESET”
then reboot router.
Everything work fine, but you will completely lose the ability to enter AT command.
Note MC7304 USB composition:
0 - reserved NOT SUPPORTED
1 - DM AT SUPPORTED
2 - reserved NOT SUPPORTED
3 - reserved NOT SUPPORTED
4 - reserved NOT SUPPORTED
5 - reserved NOT SUPPORTED
6 - DM NMEA AT QMI SUPPORTED
7 - DM NMEA AT RMNET1 RMNET2 RMNET3 SUPPORTED
8 - DM NMEA AT MBIM SUPPORTED
9 - MBIM SUPPORTED
10 - NMEA MBIM SUPPORTED
11 - DM MBIM SUPPORTED
12 - DM NMEA MBIM SUPPORTED
13 - Config1: comp6 Config2: comp8 NOT SUPPORTED
14 - Config1: comp6 Config2: comp9 SUPPORTED
15 - Config1: comp6 Config2: comp10 NOT SUPPORTED
16 - Config1: comp6 Config2: comp11 NOT SUPPORTED
17 - Config1: comp6 Config2: comp12 NOT SUPPORTED
18 - Config1: comp7 Config2: comp8 NOT SUPPORTED
19 - Config1: comp7 Config2: comp9 SUPPORTED
20 - Config1: comp7 Config2: comp10 NOT SUPPORTED
21 - Config1: comp7 Config2: comp11 NOT SUPPORTED
22 - Config1: comp7 Config2: comp12 NOT SUPPORTED
Will this work with any modem or just this one and only within ROS V7.
I’m not trying highjack the thread, but I’m having this issue in ROS 6.47beta35 with a LM940. It’s enabled but no LTE. Pins are taped etc..
