RouterOS version 6.10
I have about 100 RB951Ui routers and all are on version 6.5.
I want to upgrade them to version 6.10, but i don’t know where to get it.
I can download the version 6.9 npk file and do the upgrade, but I can’t find the version 6.10
100 times login … :wink:). Next update the same procedure …
I would setup TheDude, upload the Image to the Dude and make upgrades with the dude.
First time it takes longer as you’ve to enter password for each device.
But next and following updates are done with a few clicks.
can do this with the command line, so basically somebody could write some “plink” script, or something like that
Donwload 10MB on each mikrotik? I’d prefer to download it and then upload it on each device.
The devices aren’t on the network yet, we’ll deploy them on remote sites so I thought, I need to update them to the latest before we deploy them.
No problem!
Finally! Thanks!
I overlooked that part
