RouterOS version info...
Hi all;
If I want to know that which version of RouterOS is installed on my Mikrotik router, how can I do that?
@ terminal type “system package print” without quotes or go system>packages and u will see instaled packages and ROs verion. Or just take a look at upper left corner - ect. admin@192.168.1.1(AP_Warehouse-5) Winbox - v4.3 on RB433UAH (mipsbe)
Thanks for your reply;
Does the system section of the output says the RouterOS version?
Sorry - can’t get your idea?
yes that is it, you have 4.3 installed on the router.
