RouterOS Virtual Labs
yes, winpcap is already installed and working fine.
I dont think this is the problem.
I am running windows 7 over bootcamp in my mac, do you think that is the reason for not working properly ?
BootCamp is identical to just running on any other PC. So I don’t think related to this fact.
OK, then what else should i check ?
Thanks Normis!!
I’m loving simulating Mikrotik networks in GNS3.
I’m having a trouble simulating Mikrotiks with more than 8 interfaces.
I am currently running Mikrotik’s official cloud hosted router (CHR) image Cloud Hosted Router - MikroTik RouterOS
I am running GNS 1.3.10 on MacOS with the bundled qemu 0.14.1-gns3-osx
My virtual mikroiks are qemu emulated and use e1000 interfaces.
My problem is this:
  • If I check the “use legacy networking mode” on my virtual routers - I can link their interfaces together, which is great. However, routers configured with more than 8 interfaces wont start, and cant be connected to
  • If I uncheck the “use legacy networking mode” on my virtual routers - Routers with more than 8 interfaces will start, and i can connect to them. However, as soon as I link their interfaces together…the routers will no longer start and can’t be connected to.
So I’m a bit stuck between a rock and a hard place. My network configurations need routers with more than 8 interfaces, but I need to connect them together.
Any troubleshooting advice greatly appreciated!
If anyone else finds this question - I solved my problem through some assistance in the GNS3 forum:
https://community.gns3.com/message/48849#48849
The version of qemu bundled with GNS3 1.3.10 on OSX was older (0.14.1). I installed a newer version of qemu via homebrew (qemu 2.3.0) and everything works well. I can now run virtual Mikrotiks in GNS3 with 8+ interfaces and successfully link them together.
Hi, Normis
Do you know if the CHR works on Windows 7 32bit ?
in what software ?
GNS3 with qemu
Hi Normis,
Is it possible to provide a guide on installing GNS3 and QEMU on osx ?
Can we use virtualbox instead of Qemu, is it working properly ?
See first post in this topic. it is Windows and GNS
So we cannot run this setup on Windows 7 32bit ?
The CHR uses 64bit kernel. You have to have virtual environment to accommodate that. 32bit mode was scrapped altogether for the CHR.
CHR can’t run on Windows 32Bit, because it is 64Bit.
All Intel Core CPUs support Windows 64bit. Why are you running 32Bit Windows? Most likely your CPU supports 64Bit Windows.
I am running windows in my MAC over bootcamp but it only support windows 7 32bit thats why i told you if you can support Windows 7 32bit
Bootcamp does support Windows 64Bit actually.
Also, why do you need Windows at all? You can run VMware or GNS3 on MacOS directly. Then you will have CHR support also
I ve tried to run it on my MAC also but it didn’t work
My MAC is a MACBOOK late 2007 model and does support only GNS 0.84 vesrion and not the latest one
I had also many problems with qemuwrapper
I will try to run windows 7 64bit on Paralles i believe this should work without any problems
Thanks for your help
Hi, Normis
I ve installed Windows 7 64bit and am still getting the following message when i am trying to connect to console
127.0.0.1:2049 network error:connection refused\
But if select to reload the router i am able to login to Mikrotik console.
I
Sorry but still, even that CPU is 64Bit :slight_smile: As for the OS, I think you could upgrade to a newer one, where a better GNS is supported. Even 2008. Macs support newer OS.
And if it can’t run a newer OS than 2007, maybe you should not use such machine for Virtual Environments either.
