Not sure if it’s my pc or not (It worked on RouterOS v4.16) but if I click on an active host in hotspot to bring up it’s details and then hit the “make binding” button it will cause winbox to crash.
Tried downloading the version of winbox from the router to make sure I had the correct version and it still happens.
Also occurs if you right click and press “make binding” on the context menu.
error is as follows.
Faulting application name: winbox.exe, version: 0.0.0.0, time stamp: 0x4d528182
Faulting module name: roteros.dll, version: 0.0.0.0, time stamp: 0x4d4bd3d6
Exception code: 0xc0000005
Fault offset: 0x00023677
Faulting process id: 0x7cc
Faulting application start time: 0x01cbcabc7f6f3adc
Faulting application path: C:\Users\Dragon.Dragon-PC\Downloads\winbox.exe
Faulting module path: C:\Users\Dragon.Dragon-PC\AppData\Roaming\Mikrotik\Winbox\5.0rc9-3585860879\roteros.dll
