hello,
i have RouterOS x86 running in a virtual machine (bhyve on FreeBSD 15.0). the virtual machine has four Ethernet PCI network devices:
2 device="00:05.0" name="Virtio network device (rev: 0)" vendor="Red Hat, Inc." category="Ethernet controller" vendor-id="0x1af4" device-id="0x1000" irq=10 memory=0xC000E000-0xC000FFFF io=0x2080-0x20BF
3 device="00:05.1" name="Virtio network device (rev: 0)" vendor="Red Hat, Inc." category="Ethernet controller" vendor-id="0x1af4" device-id="0x1000" irq=10 memory=0xC000C000-0xC000DFFF io=0x2040-0x207F
4 device="00:05.2" name="Virtio network device (rev: 0)" vendor="Red Hat, Inc." category="Ethernet controller" vendor-id="0x1af4" device-id="0x1000" irq=11 memory=0xC000A000-0xC000BFFF io=0x2000-0x20DF
5 device="00:06.0" name="T540-CR Unified Wire Ethernet Controller [VF] (rev: 0)" vendor="Chelsio Communications Inc" category="Ethernet controller" vendor-id="0x1425" device-id="0x5803" irq=0
memory=0xC0012000-0xC0012FFF,0xC0000000-0xC01FFFFF,0xC0008000-0xC0009FFF
however, while the “Virtio” devices are detected correctly, the Chelsio VF is not:
[admin@lab1.i.lfns.org.uk] /system> /interface/print
Flags: R - RUNNING
Columns: NAME, TYPE, ACTUAL-MTU, MAC-ADDRESS
# NAME TYPE ACTUAL-MTU MAC-ADDRESS
0 R ether1 ether 1500 06:00:00:00:05:08
1 R ether2 ether 1500 06:00:00:00:05:09
2 R ether3 ether 1500 06:00:00:00:05:0C
3 R lo loopback 65536 00:00:00:00:00:00
i assume this is because the kernel is missing a driver for this card. is there some kind of HCL for RouterOS x86 that lists supported drivers? or is it worth asking MikroTik support to add the appropriate driver?
unfortunately i can’t use CHR as it doesn’t support bhyve (because MikroTik apparently wrongly believe it’s paravirtualisation).
