RouterOS + XR2.6
I have a XR2.6 (Ubiquit special designed for 2.6Ghz) is detected by RouteosOS v3.6, but i just only see the range of 2.4Ghz, I have another equipments with EMP-8602+S with license and the list of frequency is from 2.1Ghz to 2.5Ghz, and I want to test from 2.6Ghz to 2.7Ghz.
I tested in a RB150 and I planed to use this card in a RB600
Any suggestion.
You need superchannel.
the superchannel license that I have is from 2100Mhz to 2539Mhz, that’s the problem; it is possible to buy a license to go from 2300Mhz to 2700Mhz
If you get the XR2.6 to work in the 2.5-2.7 band please let me know. I have only been able to get it to work up to 2.528 ghz. Be aware that channels above 17 appear to rollover to the 2.3 band. The chip spec from Atheros gives a 2.3 to 2.5 range, I begin to suspect that it cannot go above 2.528.
Thanks. M.
no, superchannel unlocks whatever frequencies are supported by the card. for some cards this includes 2.5-2.7
apparently the card’s supported frequencies are detected incorrectly. I don’t know, we haven’t tested this model.
