RouterOSv3 problem
I install it on RB-112(eth1, wlan1, wlan2) and it get crazy(CPU 100%), I format nand than try again at the first time it was OK, but I restart it after which I lose “wlan2”(interface - eth1, wlan1) after next reboot I have this (interface - eth1, wlan2) I make supout.rif files each time the CPU was 100%, after that I downgrate to v2.9.50 I have (interface - eth1, wlan1, wlan2)
who can explane me what is the problem, the RouterOSv3.0 didn’t work on RB-112 or it’s another problem.
Thank’s all in advance.
supout3.0.zip (146 KB)
Uninstall packages you don’t need and turn off connection tracking.
