Routes - DIO Next to address ?
Hello. Recently I’ve started working with miktorik and on some of my routes list, there are several address that I think they are bad and I want you to explain me what does it mean DIO next to address and why is it red…
Please check out the printscreen in my attachment… Should I delete em or what should I do ?
If anyone can assist me with this, please do.
Thanks in advance.
Alex
Dynamic, Inactive, OSPF
http://wiki.mikrotik.com/wiki/Manual:IP/Route#Route_flags
If you cross over the flags with the mouse, it will explode the notes
Thank you very much. Now tell me. Should I delete those or ?
You can’t. They’re dynamically learned over OSPF, but not used because you have a connected routes to those same subnets which take precedence.
Thank you very much. It’s seams there’s ton of stuff I have to learn still.
Thanks for the great answers, I really appreciate it.
Best wishes,
Alex
