I hope you can help because I am new at this and I didn’t find a solution for it on google search.
I have 3 networks
192.168.0.1/24
10.10.0.0/22
10.20.0.0/22
I also have three WAN connections
62.x.x.x
85.x.x.x
74.x.x.x
For the moment all networks goes to 0.0.0.0 action masquerade and in routing I have distance 1 on 62.x.x.x, distance 2 on 85.x.x.x and distance 3 on 74.x.x.x
I am trying to do the following :
10.10.0.0/22 should work with WAN 62.x.x.x (distance 1), 85.x.x.x (distance 2), 74.x.x.x (distance 3)
so it should direct all traffic to 62.x.x.x but use 85.x.x.x if 62.x.x.x goes down and so on…
10.20.0.0/22 should work with WAN 85.x.x.x (distance 1), 62.x.x.x (distance 2), 74.x.x.x (distance 3)
so it should direct all traffic to 85.x.x.x but use 62.x.x.x if 85.x.x.x goes down and so on…
Can you please help me and give me some instructions on how to do that?
If you are confused on your posting as you are on your config yes you do need help.
You fail to mention the 192.168.0.1 network LOL. Try again…
so it should direct all traffic to 62.x.x.x but use 85.x.x.x if 62.x.x.x goes down and so on… 10.10.0.0/22 should work with WAN 62.x.x.x (distance 1), 85.x.x.x (distance 2), 74.x.x.x (distance 3)
I could guess that both 10.10.0.0 and 192.168.0.0 have the same requirement and its only 10.20.0.0 that is different but will wait for clarification.
192.168.0.1 should work with WAN 62.x.x.x (distance 1), 85.x.x.x (distance 2), 74.x.x.x (distance 3)
To simplify:
Subnets A,B have the same requirement as each other (ISP1–>ISP2–>ISP3)
Subnet C, has the first two reversed (ISP2–>ISP1–>ISP3).
Conceptually this is what needs to be done.
STARTING POINT
add dst-address=0.0.0.0/0 gwy=ISP1 dist=5 check-gateway=ping
add dst-address=0.0.0.0/0 gwy=ISP2 dist=10 check-gateway=ping
add dst-address=0.0.0.0/0 gwy=ISP3 dist=15 check-gateway=ping
In this manner subnets A,B,C will use the WAN connections in the following order ISP1, ISP2, ISP3. This is great for subnets A,B and thus we have limited the issue to subnet C.
To redirect Subnet C, to an alternate ISP we need to create 3 items: routing table, routing rule and additional route.
Now all the users on subnetC, will be directed out ISP2. If ISP2 is not available, the users will then go out ISP1 as an available route on the main table with shortest distance. If ISP1 is not available they will be moved to ISP3. At any point in time ISP2 comes back online, the users will be moved back to ISP2.
Above assumes firmware ver7
If Vers6 then its really two steps… (add routing mark in the duplicate ip route, and the associated routing rule)
I tried what you recommended and it worked but also made other things not work
For example communication between networks B and C stop working. Do you think there is a way to implement your solution but also keep networks B and C communication?
Even without config, if there’s routing rule telling traffic from 10.20.0.0/22 to use another routing table in which is only route to internet and not to local subnets, it makes everything from that subnet go to internet. So you need another routing rules before that, to reach local subnets, e.g.:
Concur, but also wanted to ensure there were not other issues as well at play.
The most important KEY is that those rules (order being important) need to show up on the config before/prior to the table=useWAN2 rule.
This provides the routing possibility for the 10.20.0.0 subnet to reach the other local subnets, and this can be blocked or allowed by firewall rules as the admin sees fit.
Note that these additional routes makes use of destination address not source address and use table main.
/routing rule
add dst-address=192.168.0.0/16 action=lookup-only-in-table table=main - matches/captures all traffic heading to 192.168.0.0 (from any subnet)
add dst-address=10.0.0.0/8 action=lookup-only-in-table table=main - matches/captures all traffic heading to 10.0.0.8 (from any subnet)
add src-address=10.20.0.0/22 action=lookup table=useWAN2 - matches/captures all traffic from subnet 10.20.0.0, not captured by the two previous rules, and sends it to WAN2.
It is possible to use both source and destination address on the rules, but as SOB didnt, he is either lazy or more likely realizes that its unecesssary, as destination-address only gets the job done (efficient) and there is no conflict on what the OP whats to occur. As stated, traffic between subnets is controlled by firewall rules. Routes are just making paths available for traffic flow.
