I have had problems with routes that once disconnected are not removed from the routing table, ex:user X logs in and receives ip 10.1.0.1, within the area and created a route to this ip, after the user disconnects in some cases the route remains there when another client at another point with the same ip that was being using by the user X, is the problem since the route is pointing to the wrong place, so I’ve been seeing automatic route can not be removed manually, the only way I have found to solve this problem and restarting the router, but this not practical for me, because besides the overthrow of the network going down many users together, someone here knows why this problem occurs and how can I solve it? or at least a way I can remove these routes (ghosts) manually? thanks =) sorry for my english by google translator
google rules - almost good translation ))
what version do you use? try 3.30 + routing-test or v4.2
I use version 3.30. without routing test, I put one in here, most not seen anything more ha not, until now not understood what changes the normal version for routing test. even with rountig test can not I remove those routes: (
routing-test have most improvements and fixes. it’s regular ‘routing’ package for v4. and, as far as I remember, such problem was fixed by latest version + ‘test’ package
man, you are my hero, always helping =) if you have msn or skype is there, and always good to have friends around: P
I will test here, to having problems with my clients right here so
unfortunately, there’s no ‘Skype’ field in forum’s profile - Normis, could you please add it? =)
http://www.phpbb.com/mods/db/index.php?i=misc&mode=display&contrib_id=6285
by what I understood to solve my situation I need to download version 4, plus she and beta, it works as it should? you use them there?? she has some kind of instability? I have over 200 mkts on my network, I wanted to be sure everything before upgrading. again thanks friend
huh, that was your thread %) http://forum.mikrotik.com/t/problems-with-ospf-routes-that-are-not-removed-after-use/31361/1
well, then check 4.2 on one of your routers, and if it still behaves abnormally - make supout.rif and send it to support…
And you’re right, I had already opened a topic in the season, I had upgraded and had resolved, the more the problem happen again. I walk with problems in my link here, then my head is full, I’m sorry to have opened another topic. I will update this for version 4 and let’s see what happens. thanks for help
ospf area upgraded one yesterday for my version 4.2, the most ever met a problem, I use frequence mode= super channel in one rb mine, right after the upgrade that kind of attendance do not want more work, I had to use downgrade, as you know I use super channel in version 4.2?
you need to write to support@mikrotik.com, I think
