We’ve got a Cisco 7200 routing a /30 to a StarOS box, here’s the general setup:
Cisco → StarOS1 → StarOS2 → Mikrotik → StarOS3
routing 12.127.84.200/30
StarOS1: 12.127.84.138
StarOS2: 12.127.84.210
StarOS3: 12.127.84.218
Mikrotik: 12.127.85.114 (different class c)
Routing 12.127.84.200/30 from the cisco to StarOS1 then to StarOS2 and to the Mikrotik to the StarOS3 with 12.127.84.201 as an ip on it, but it won’t ping or traceroute. intermittently I can get a few pings through and when I can’t ping it the traceroute stops after 12.127.85.114 (the mikrotik).
I backed up a step to test this out so I took the route out of the Mikrotik and just added an ip to the mikrotik as 12.127.84.201 and then I can ping it all day long without problems. Why am I getting intermittent pings through when routing past the mikrotik?
On the mikrotik: Destination 12.127.84.200/30 Gateway 12.127.84.218
is there something else I’m missing? Again, the /30 is good all the way to the mikrotik but not past. We’re in the process of migrating a lot of our units to mikrotik but this problem needs to be resolved first.
thanks
