can someone explain this please? Running RC10, I need this fixed ASAP… The router was fine, over a period of time (less than 24hrs) it started doing this.. Dual Core Intel system with 2GB of RAM, system resources is hardly a issue…
[cknipe@CTN-CORE01] > /ip route print
# DST-ADDRESS PREF-SRC G GATEWAY DIS
[cknipe@CTN-CORE01] > /ip address print
# ADDRESS NETWORK BROADCAST INTERFACE
0 172.19.44.253/24 172.19.44.0 172.19.44.255 Internal
1 196.xx.xx.253/28 196.xx.xx.240 196.xx.xx.255 External
2 196.xx.xx.133/29 196.xx.xx.128 196.xx.xx.135 External
3 196.xx.xx.173/29 196.xx.xx.168 196.xx.xx.175 External
4 172.19.44.254/32 172.19.44.254 172.19.44.254 VRRP - Internal
5 196.xx.xx.254/32 196.xx.xx.254 196.xx.xx.254 VRRP - DigiNET MPLS
6 172.19.45.29/32 172.19.45.29 172.19.45.29 VLAN10 - High Priority
7 172.19.45.30/32 172.19.45.30 172.19.45.30 VRRP - VLAN10
Where is my routing table? Why does it not even display routes for connected networks? I have no routing table in winbox or console, adding a route manually via console or winbox does nothing. Rebooting the router does NOT fix the issue
