Routin mailsever and users trafic Through diferent IP same I
I have a mail server that is listed on blacklist SBL because all the traffic from mail server and users is going through one same public IP… I have from my ISP more than 5 public IP so what I need to do is separate the traffic in/out from specific local lan to a especific public IP for my mail server and do the same for my network users in that way my server will not be listed on black list any more if a user computer is infected with a spam virus.
This my setup RB500 using RouterOS 3.0rc7
Ether1 WAN (201.x.x.10 and 201.x.x.12) ISP public Address
Ether2 LAN DHCP Server 192.168.1.0/25
Ether3 used for database VLAN backup conections
I need to set the the 2 publics IP on ETHER1 for WAN conections so all my users will go to the internet using 201.x.x.10 in/out traffic and all the in/out traffic to the internet for my mail server will go through 201.x.x.12 to a especific local lan 192.168.1.10
All the routing policies that I see on wiki and forum is using 2 diferent IP providers and for balancing propurses, I try to use some of them but as a result I get disconected from internet.
Sounds simple enough, I bet its just a rule error. If you wish to get some help ASAP, shoot me a call, otherwise, post some more information, such as your nat rules etc, so that we can see what is goen on.
Thanks for your reply:
I have a dstnat rule for my mail server
chain=dstnat Dst.Address 201.x.x.12 Action=Dst-nat To Address=192.168.9.10
I did not set a firewall rule specific for mail server, all rules are global and only for blocking messenger and p2p
any idea of what I am doing wrong or what I miss?
Going to need all of it, alot more information is needed to figure out what you are trying to do and what you are wishing to do.
Denis
Could you be please be more especific on what info I can give you about my configuration so you can help me ? I add a image with my actual network and how is working…
What I need to do is use one ethernet to set two IPs from my ISP.. after this 2 publics IP are set I need to send all the internet request from my users (all data in/out to the internet) over a specific IP and all the internet request,hosting (all data in/out to the internet) over the second IP address set.
On this way my server will navigate using a diferent public IP than my network users.
I try network balance example with good results, my principal interest is my mail server runing a pop and webmail.
Well here is the configuration of the mikrotik, all the config of interface,ip address, routes (my vlans) I don´t have any rule on my firewall yet, my mail server have 2 NIC:
NIC-1 :192.168.9.10
NIC-2 :192.168.9.19
I want to send my mail server traffic through a specific public IP 201.xx.xxx.99, and all the traffic of my vlans and locals users will use a different public IP to navigate the internet
[admin@B&V Firewall] /interface> print
Flags: X - disabled, R - running, D - dynamic, S - slave
NAME TYPE MTU
0 R WAN ether 1500
1 R LAN ether 1500
2 R BACKUP ether 1500
[admin@B&V Firewall] /ip address> print
ADDRESS NETWORK BROADCAST INTERFACE
0 ;;; added by setup
201.46.253.98/29 201.xx.xxx.96 201.xx.xxx.103 WAN
1 ;;; added by setup
192.168.9.4/24 192.168.9.0 192.168.9.255 LAN
2 X ;;; added by setup
201.xx.xxx.102/29 201.xx.xxx.96 201.xx.xxx.103 BACKUP
3 201.xx.xxx.100/29 201.xx.xxx.96 201.xx.xxx.103 WAN
4 201.xx.xxx.99/29 201.xx.xxx.96 201.xx.xxx.103 WAN
5 201.xx.xxx.101/29 201.xx.xxx.96 201.xx.xxx.103 WAN
[admin@B&V Firewall] /ip route> print
DST-ADDRESS PREF-SRC G GATEWAY DISTANCE INTERFACE
0 A S ;;; added by setup
0.0.0.0/0 201.xxx.xxx.99 r 201.xx.xxx.97 1 WAN
1 A S ;;; EUROCOCINAS
192.168.1.0/24 r 192.168.9.1 1 LAN
2 ADC 192.168.9.0/24 192.168.9.4 0 LAN
3 A S ;;; TERRAMAR
192.168.10.0/24 r 192.168.9.1 1 LAN
4 A S ;;; AQUALINA
192.168.11.0/24 r 192.168.9.1 1 LAN
5 A S ;;; SEVILLA
192.168.12.0/24 r 192.168.9.1 1 LAN
6 ADC 201.xx.xxx.96/29 201.xx.xxx.98 0 WAN
:smiley: I receive a response from Mikrotik support department and I solve my problem. Here is the reply I get from them.
I hope this work for any one in the future with a issue that apply
please look at this destination nat example:
http://www.mikrotik.com/testdocs/ros/2.9/ip/nat_content.php#6.36.3.3
you are missing a src-nat rule
Regards,
Uldis
