pedja
September 22, 2011, 8:21am
2
I guess you have set NAT to interface.
When you set NAT rule set source IP address range to one you want NAT to work for. IP’s that are not in specified range won’t NAT.
get2guy
September 22, 2011, 8:10pm
3
Is at a customer that you need to assign is own “real” IP?
If yes, you can create a routing mark and src-NAT that routing mark to a different IP
First mark the network:
chain=prerouting action=mark-routing new-routing-mark=1.0 network
passthrough=yes src-address=192.168.1.0/24 in-interface=ether2
Then src-NAT to another address(8.8.8.8=“real” IP, ether1=WAN):
chain=srcnat action=src-nat to-addresses=8.8.8.8 routing-mark=1.0 network
out-interface=ether1
Q: in your 7 note, you wrote “so i can route that network in and out as-is”
are you pointing the 1.0/24 network to another network (not internet)? for example: Bridge between 2 office branches
Hope it helps…
Hello friends,
Thanks for all your reply. I got it working with only this:
/ip hotstpot ip-bindings add address=192.168.1.0/24 type=bypassed
The thing is the hotspot is binding a 192.168.0.0 address to every 192.168.1.0 address seen.
Thanks for all your replies. I learned from them.
Best regards,
MarlboroMan
fewi
September 23, 2011, 3:41am
5
To stop that set the adress-pool property of all user profiles and all hotspot profiles to ‘none’.
http://wiki.mikrotik.com/wiki/Manual:Hotspot_Introduction#Getting_an_Address
