Routing all traffic from a machine to another
I’m in a situation where I’d like to work from a linux machine (linux vm guest) through another vm (win10 guest).
Why? cause I need a VPN for my work where the VPN client only works with windows (f5 vpn client doesn’t pass the antivirus check on the linux machine, don’t know which antivirus is supported by the f5 client f5epi)
Think in theory there are 2 options, configure the mikrotik for routing all the traffic from linux vm through the win vm.
Is it possible to do that and if yes how?
