Routing and bad bandwith
I have a throughput of approx. 18 MB/s if I connect 3 MT servers (PC) about wireless and let these go in the wds mode (bridge).
If I let the net with ospf go, I get 12 MB/s throughput only. (MT1 – MT3)
I get a bandwith of 17 MB/s if data flow from MT1 to MT2.
I get a low bandwith if data flow from MT1 to MT3.
Why?
MT1 --(wireless)-- MT2 – (wireless)-- MT3 – Laptop
Every wireless interface has another subnet.
I have better result with routing-test package…
routing-test package is installed.
Can I bonding two wireles interface with OSPF?
I need min. 30 Mb/s Bandwith.
sorry, i don’t know :frowning:
i have such question about OSFP, answer has not got :frowning:
topic - http://forum.mikrotik.com/t/ospf-load-balancing-on-wds-connections-please-help/11165/1
What are the hardware spec’s of the routers (ie: CPU, RAM)?
Hi wildnill442.
I put a server with a celeron CPU of 2.4 GHZ and 512 MB of RAM.
Unfortunately, I do not get the desired speed.
I hope you have a solution for my problem.
I imagined now to bundle two Wireless cards.
Does this go also with OSPF?
