Routing and NAT with Mangle Rules.. no go?
have a quick question.
I am natting 5 IP addresses
Ip firewall nat
0
chain=dstnat in-interface=eth2_outside dst-address=xx.79.169.22
protocol=tcp dst-port=80 action=dst-nat to-addresses=192.168.1.234
to-ports=8080
1
chain=srcnat src-address=192.168.1.234 protocol=tcp action=src-nat
to-addresses=xx.79.169.22 to-ports=0-65535
2
chain=dstnat in-interface=eth2_outside dst-address=xx.79.169.19
protocol=tcp dst-port=80 action=dst-nat to-addresses=192.168.1.231
to-ports=8080
3
chain=srcnat src-address=192.168.1.231 protocol=tcp action=src-nat
to-addresses=xx.79.169.19 to-ports=0-65535
4
chain=dstnat in-interface=eth2_outside dst-address=xx.79.169.21
protocol=tcp action=dst-nat to-addresses=192.168.1.232 to-ports=80
5
chain=srcnat src-address=192.168.1.232 protocol=tcp action=src-nat
to-addresses=xx.79.169.21 to-ports=0-65535
6
chain=dstnat in-interface=eth2_outside dst-address=xx.79.169.23
protocol=tcp dst-port=80 action=dst-nat to-addresses=192.168.1.233
to-ports=8080
7
chain=srcnat src-address=192.168.1.233 protocol=tcp action=src-nat
to-addresses=xx.79.169.23 to-ports=0-65535
8
chain=dstnat in-interface=eth2_outside dst-address=xx.79.169.30
protocol=tcp dst-port=80 action=dst-nat to-addresses=192.168.1.235
to-ports=80
9
chain=srcnat src-address=192.168.1.235 protocol=tcp action=src-nat
to-addresses=xx.79.169.30 to-ports=0-65535
The problem I have is also need to route traffic for the internal VPN on 10.0.0.0/24 to 192.168.1.1 (VPN gateway device)
So we have
VPN 10.0.0.0/24
192.168.1.1/24 VPN GW device
Switch---------MT 192.168.1.2/24
| Internet IP space xx.79.169.0/27
Computers 192.168.1.0/24 gw at 192.168.1.2
When traffic comes from 192.168.1.1 as src-adddress of 10.0.0.24 and hits the computers at 192.168.1.21 for example. The MT at 192.168.1.2 see the NAT rules and does not route the traffic properly.
I have tried setting a mangle rule for dst-address 10.0.0.0/24 so it can route back properly and not hit the NAT rules.
[admin@MikroTik] ip firewall mangle add action=mark-routing new-routing-mark=nonat chain=prerouting
[admin@MikroTik] ip route> add gateway=192.168.1.1 routing-mark=notnat
[admin@MikroTik] ip route rule> add dst-address=10.0.0.0/24 table=notnat action=lookup
[admin@MikroTik] ip route rule> print
0 sdst-address=10.0.0.0/24 action=lookup table=notnat
This does not seem to work and the traffic appears to be hitting the NAT rules still.
I have tried a few other things and still no go. I just put 2.9.30 up as well. still no change.
Any ideas?
Tim
Can you put NAT rules in at the top of the chain the perform ‘return’ action if they are coming from the source nets / interfaces that you dont want to nat ? Dump them out of the NAT chain early to bypass nat for them ?
Sam
I dont know. I figured marking the dst-address with a routing-mark to be routed in prerouting would get them to route before the nat rules. It is not the src or interface I am trying to route by but the dst-address that they want to get to, the vpn traffic.
Clients need a route on them that indicates that the 10.0.0.0 network is behind the 192.168.1.1 gateway.
Regards
Andrew
