I have a relatively standard Mikrotik setup where the VPN connections appear as interfaces, with /32 . The internal machines are in a bridge ether3-ether5, with the upstream directly connected in ether1.
I’m not sure if my problems started with some configuration changes on our part or my providers changed some internal parameters. As the problem seems to start happening with the 4
I used to be able to reach the internal machines from the VPN, and I’m still sort of, but I’m seeing a problem where the bridge is no longer reachable from the VPN, and every time I try to ping one of the internal addresses from the VPN (beyond the 192.168.XX.1 gateway, which works), the result is an entry added to the upstream arp table, like:
[admin@MikroTik] > /ip arp print where address~"XX"
Flags: X - disabled, I - invalid, H - DHCP, D - dynamic, P - published, C - complete
# ADDRESS MAC-ADDRESS INTERFACE
0 DC 192.168.XX.NNN SO:ME:MA:CA:DD:RE ether1
1 DC 192.168.XX.NNN SO:ME:MA:CA:DD:RE ether1
2 DC 192.168.XX.NNN SO:ME:MA:CA:DD:RE ether1
The SO:ME:MA:CA:DD:RE is the address of my upstream router, which seems to have a greedy proxy-arp set up. I have since set “secure-redirects” to no, to see
if the Mikrotik was redirecting the internal machines to use directly the VPN gateway, not reachable to them… No difference.
Now, I don’t understand why is the Mikrotik even doing arp in the upstream. The error is driving me crazy and I need to fix it.
It seems to be erratic but sticky, as if depending of some hw acceleration or initialization order: typically some of the VPN work, others don’t.
Now, the routes seem to be right from the limited way we can question the router:
[admin@MikroTik] > /ip route check 192.168.XX.NNN
status: ok
interface: <l2tp-user>
nexthop: 192.168.XX.NNN
(the result does not change for any router IP address that we use in src-ip)
I would need either a way to avoid the arp lookup or a way to fix the effective routing, as it is randomly impeding my VPN<->internal traffic, which is the primary reason why we use a VPN.
It is very difficult to debug the packets flowing, but it looks like the Mikrotik sometimes, instead of using the router that /ip route check returns (see above) tries to send those packets through its own the default route, where the sticky proxy arp eats them ![]()
When I do the ping from one of the “unreachable” machines, like (ZZ is the bridge network, XX the vpn one):
[admin@MikroTik] > /system ssh address=192.168.ZZ.NNN user=root command="ping -c 4 192.168.XX.NNN"
password:
PING 192.168.XX.NNN (192.168.XX.NNN) 56(84) bytes of data.
--- 192.168.XX.NNN ping statistics ---
4 packets transmitted, 0 received, 100% packet loss, time 2999ms
Welcome back!
YY.NNN is one machine in the internal network, unreachable from the VPN, but perfectly from the router. It
has only one default route:
[admin@MikroTikParc] > /system ssh address=192.168.YY.NNN user=root command="ip route; echo; ip route get 192.168.XX.NNN"
password:
default via 192.168.YY.1 dev eth0
192.168.YY.0/24 dev eth0 proto kernel scope link src 192.168.YY.NNN
192.168.XX.NNN via 192.168.YY.1 dev eth0 src 192.168.YY.NNN
cache
Welcome back!
Any help would be welcome.
Regards,
Santiago
