ether1 able to ping into ether2 but the problem is ether2 cannot ping into ether1, both internet access are fine. How to allow inter-connection between ether1 and ether2?
Yes client on ether2 cannot ping/access client on ether1, client on ether1 has purposely enabled to accept icmp by default, so it’s not firewall issue on the ether1 client.
Here is it
# ADDRESS NETWORK INTERFACE
0 10.8.8.1/24 10.8.8.0 ether1
1 10.9.9.1/24 10.9.9.0 ether2
2 D 40.111.222.33/32 40.111.222.1 Internet
Pinging from a client in 10.9.9.0/24 to 10.9.9.1 is succeed, the same wtih 10.8.8.1 gateway, strangely with ping to a client in ether1 is failed with request time out error.
ether2 client was windows 8.1 64 bit Pro, ether1 client was Windows 10 64 Bit Enterprise.
Finally found out that windows firewall on windows 10, it looks like blocking icmp by default !, fixed by either disabling windows firewall or adding icmp rules.
Now i can ping from ether2 client to ether1 client! thx descartes, but now the problem is getting weird, even-tough i can ping, i cannot access a ftp server in which hosted in one of the client in ether1!, the error from the ftp client just connection reset by peer on ether2, my ftp server on ether1 is running on port 5420.
Do you have any idea on why ether2 client cannot access the ftp server on ether1?. Is there any firewall rules that i should be add?.
yes, windows by default will not reply to a icmp from another subnet, this is what I was getting at.
we need to investigate more on the ftp.
on the nat masquerading, this is the correct way (there in no other way I can think of).
However, please note that there are times when you want to have full IP access to each other on both LANs, for example some protocols do not work well on NAT scenario (e.g. SIP) and so doing nat (masq) might not be a good idea, we do (nat/masq) when we want to block, protect, or even preserve IP address-es, just like we normally do with a router or internet gateway.
Sure, you’re now NAT’ing between the subnets, but your original question was routing between the subnets. If you want to simply route, delete those two masquerade statements. While your FTP may work now, your SMB/CIFS traffic will now be broken.
@descartes@JJCinAZ
So how i am able to properly make these 2 subnet communicating each other in any other protocol, other than icmp?, without breaking any protocol of course.
I am also noticing that the ftp server detected the ip of client on ether2 as 10.8.8.1 which is ether1 gateway. How to route and reserve the ip of the ether2 client on ether1 ?
I think this is the point that we are making, if you take 2 subnets and make them NAT(MASQ) on both sides, all we see is the IP address-es of each gateway (10.8.8.1 or 10.9.9.1). And we have to do the DNAT, in order, for example to make your FTP to work.
In a normal routing way, especially when we manage both subnets, we should allow all traffic to pass freely without any translation, in the default mode, all routers would not do any translations (dnat,snat, etc), between subnets or network interfaces in this case. Unless there is a specific reason (e.g. security or otherwise), we normally we would allow all the traffics to go through.
With no firewall rules to worry, we then just move forward to work on other issues which is normally on the application layers, like FTP, Windows Share (SMB), printing, etc.
Thanks for the explanation, but i am still couldn’t figuring out on how to make translation between subnet, DNAT as you have mentioned is destination-nat?, i have now modified the rules as following :
But those rules broke everything, couldn’t access internet, lan inter-connection broke. Would you please give an example about your explanation in my case as a mikrotik rules?.
Strangely without any masquaerade rules for lan, iperf on port 5201 works flawlessly, while ftp on port 5420 broke. What i want to do is to expose all available 65534 port both tcp and udp for both lan in order both of them to inter-communicating.
Disable all the rules in the Forward chain on firewall filters:
:foreach i in=[find where chain=forward] do={disable $i}
If you can’t communicate between the subnets, then you have issues with host configurations on the subnets (e.g. bad network masks, bad default gateways, extraneous routes, etc.).
If you can communicate between subnets, then you can add back forward filter rules until you see what breaks.
@JJCinAZ
Thanks but on my firewall filter, there is no rules for forward chain, only rules to block port scanner/nmap.
I have just re-checked my lan setup, both (ether1 and ether2) of them are fine, no erroneous gateway/dns server,all of the routes are only the default one that are generated by mikrotik.
The current problem is i can ping/iperf from each of them but cannot access a ftp server on ether1 client from ether2 client, unless i am also masquerade ether1 and ether2 which is not a proper solution because the detected client ip would be from the gateway, so i need a way to inter-communicating each of them with preserving its IP.
I am pulling my hair out on why iperf works fine without masquerade both lan.
Edit :
Duh found out it’s a software issue! after diving into my ftp server log, i have forgotten to include the IP to allow list in my ftp server!. My mistakes on my end, i apologize. The ftp client wasn’t output the correct log, other than connection reset by peer, not IP restrictions log, hence made me to think that the connection wasn’t go through, and straightly thinking it’s a routing/mikrotik issues.
Thanks goes to descartes and JJCinAZ who are patiently walk-through my problems. I hope everything will goes really well to you both. Cann’t thank you enough.
