I have a normal cable modem setup with a Mikrotik router. In the area, there is also a Spectrum (ISP) hotspot which the customer has access to. I would like to be able to switch to using this for internet access.
I’ve created a second bridge, a wifi interface in station mode that connects to the Spectrum hotspot, and a DHCP client on that second bridge. It successfully gets an IP address.
To test it out, I want to just try routing access to one IP address (my web site).
I tried adding a new route with Dst. Address of my web site, and the second bridge as the gateway.
Am I missing something? Perhaps I should be adding some kind of masquerade, and/or the route gateway should be the Wlan, not the Bridge?
have you internet access by cable at modem??
you give internet to router and want pass internet to your lan network with wireless interface
step1:you set ip to wireless interface
step2:set dhcp on wireless interface
step3:masquerade the subnet of wireless IP
You can only specify an interface as route’s gateway if the interface is a point-to-point one. Otherwise, you have to specify an IP address as route’s gateway. The latter is definitely the case for the wireless interface.
As your two WAN interfaces are connected to different providers, each of them has a different IP subnet and a different gateway IP in that subnet. To learn the gateway for the WAN interface, configure the DHCP client to accept the default gateway but give it a distance of 2 and more, so that it wouldn’t compete with the default gateway configured or received via DHCP from the primary WAN uplink (which likely has distance=1)
Then, display the table of IP routes, you will see the IP address of the gateway received from the wireless ISP. Add a route towards your web server with that IP address as a gateway.
To make it work not only for the Mikrotik itself but also for devices connected to its LAN, your ip firewall nat rules must contain a masquerade rule in srcnat chain for both WAN interfaces (you can use interface list for that).
For a backup or load balancing configuration, you have to configure the routes statically, or use a dhcp client script to change the configuration if eventually you would get a different gateway with each DHCP address allocation (which is not very likely, though).
