Can me somebody explain, why when I made an ipsec channel between lans, on one side i getting all connections from a remote lan with the same ip for all clients? I suspect that a nat rule working, but how I can get clients original ip addresess?
add chain=srcnat comment="Pass VPN_2_VPN" dst-address=192.168.0.0/16 src-address=192.168.0.0/16
IMHO you should have similar rule at the top of your rules to prevent packets to be masquaraded.
This particular rule is taken from central router with 192.168.1.x/24 which is concentrator for some IPSEC with 192.168.x.0/24 subnets.
This rule passes all trafic between all IPSec tunnels.
At each subnet there are rules like:
add chain=srcnat comment="Pass VPN_2_VPN" dst-address=192.168.0.0/16 src-address=192.168.xxx.0/24
But I had such rule and I added another one
0 chain=srcnat action=accept src-address=192.168.111.0/24 dst-address=192.168.0.0/16 log=no log-prefix=“111______”
1 chain=srcnat action=accept src-address=192.168.0.0/16 dst-address=192.168.111.0/24 log=no log-prefix=“112__”
but it is not helped.
I have server 192.168.111.5 and all incoming connections from 192.168.x.x/24 has an ip address 192.168.111.1 ( it is local address of mirkotik )
If I correct understood action must be “accept”, is it right? If yes, then I can’t understand why it is not working
Are you sure it’ll match properly with that subnet?
Anyway I already exclude internal networks in the masquerading rule like
1 ;;; masquerade external traffic
chain=srcnat action=masquerade src-address=xxx.xxx.xxx.xxx/xx
dst-address-list=!masq_whitelist out-interface=wan log=no log-prefix=""
add subnets to the whitelist and no need for the accept rule. off course you can also just do a variant without the list but make it explicit in the rule.
unfortunately magchiel, your advise didn’t help : - ( but anyway thanks for your reply
