I’ve got a number of networks on my router…
Port 1 - PublicIP
Port 2 - 192.168.1.0/24
Port 3 - 192.168.2.0/24
Port 4 - 192.168.3.0/24
Port 5 - 192.168.4.0/24
192.168.1.2 can’t ping 192.168.2.2, 192.168.3.2, 192.168.4.2
Can someone point me at the instructions to get traffic moving between the networks?
I’ve got masq set up on port 1, so each network can see the internet… they just don’t seem to be able to see each other.
D
You should post “/ip firewall nat” and “/ip firewall filter”.
Since it is a 750, maybe you should post “/interface ethernet” also.
SurferTim:
Hi, I’m not sure what I did right or wrong, but it’s going just fine… so back to blocking the NetBT traffic now… someone else made suggestions on what to look at to do that, so I’ll set up a test and see if I can figure it out.
D
