Routing between two IPSec Tunnels
I have a setup like this
Network 1 Network 2 Network 3
RB750GL is in network 2.
I can communicate between Net 1 and Net 2, Net 2 and Net 3.
But no communication between Net 1 and Net 3?
Is it possible to crate policies for communication between 1 and 3?
I’ve tried to enable Generate Policy feture in IPsec Peers options. After some delay it creates very interesting rules like src:net1 dst=net3, sa src=mikrotik, sa dst=net1 gw. The traffic from Net 1 to Net 3 begins to flow for some time. But traffic Net 1 and Net 2, Net 2 and Net 3 stops to flow. After some time, all traffic stops to flow.
What should I do to make all traffic directions possible?
I don’t believe so. On RouterOS IPSec tunnels are not routable. You would have to use a IPIP/GRE/EOIP etc over IPSec setup.
Yes, it’s possible.
Don’t use “Generate policy” option here, it is not needed in your case.
I remember myself replying to a similar question some time ago. Have a look at this thread, it contains a working example of what you’re asking for.
Thanks a lot, it really works! You made my day! Also a had to set ‘level=unique’ instead of ‘require’ to make it work.
Thats actually really good to know…
