add admin-mac=00:00:00:00:00:00 ageing-time=5m arp=enabled auto-mac=yes
comment=“” disabled=no forward-delay=15s max-message-age=20s mtu=1500
name=bridge1 priority=0x8000 protocol-mode=none transmit-hold-count=6
set 0 arp=enabled auto-negotiation=yes comment=“” disabled=no full-duplex=yes
mac-address=00:0C:42:0A:D8:36 mdix-enable=yes mtu=1500 name=ether1 speed=
100Mbps
set 1 arp=enabled auto-negotiation=yes comment=“” disabled=no full-duplex=yes
mac-address=00:0C:42:0A:D8:37 mtu=1500 name=ether2 speed=100Mbps
set 2 arp=enabled auto-negotiation=yes comment=“” disabled=no full-duplex=yes
mac-address=00:0C:42:0A:D8:38 mtu=1500 name=ether3 speed=100Mbps
set default authentication-types=“” eap-methods=passthrough group-ciphers=“”
group-key-update=5m interim-update=0s mode=none name=default
radius-eap-accounting=no radius-mac-accounting=no
radius-mac-authentication=no radius-mac-caching=disabled
radius-mac-format=XX:XX:XX:XX:XX:XX radius-mac-mode=as-username
static-algo-0=none static-algo-1=none static-algo-2=none static-algo-3=
none static-key-0=“” static-key-1=“” static-key-2=“” static-key-3=“”
static-sta-private-algo=none static-sta-private-key=“”
static-transmit-key=key-0 supplicant-identity=MikroTik tls-certificate=
none tls-mode=no-certificates unicast-ciphers=“” wpa-pre-shared-key=“”
wpa2-pre-shared-key=“”
add authentication-types=wpa-psk,wpa2-psk group-ciphers=tkip
group-key-update=5m interim-update=0s mode=dynamic-keys name=helen
static-transmit-key=key-0 supplicant-identity=“” tls-certificate=none
tls-mode=no-certificates unicast-ciphers=tkip wpa-pre-shared-key=
/interface wireless
set 0 ack-timeout=dynamic adaptive-noise-immunity=none allow-sharedkey=no
antenna-gain=0 antenna-mode=ant-a area=“” arp=enabled band=2.4ghz-b/g
basic-rates-a/g=6Mbps basic-rates-b=1Mbps burst-time=disabled comment=“”
compression=no country=no_country_set default-ap-tx-limit=0
default-authentication=yes default-client-tx-limit=0 default-forwarding=
yes dfs-mode=none disable-running-check=no disabled=no
disconnect-timeout=3s frame-lifetime=0 frequency=2447 frequency-mode=
manual-txpower hide-ssid=no hw-retries=4 mac-address=00:0C:42:23:C1:05
max-station-count=2007 mode=ap-bridge mtu=1500 name=AP
noise-floor-threshold=default on-fail-retry-time=100ms
periodic-calibration=default periodic-calibration-interval=60
preamble-mode=both proprietary-extensions=post-2.9.25 radio-name=
000C4223C105 rate-set=default scan-list=default security-profile=default
ssid=casahelen station-bridge-clone-mac=00:00:00:00:00:00
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps
supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps tx-power-mode=default
update-stats-interval=disabled wds-cost-range=50-150 wds-default-bridge=
none wds-default-cost=100 wds-ignore-ssid=no wds-mode=disabled
wmm-support=disabled
set 1 ack-timeout=dynamic adaptive-noise-immunity=none allow-sharedkey=no
disconnect-timeout=3s frame-lifetime=0 frequency=2462 frequency-mode=
manual-txpower hide-ssid=no hw-retries=4 mac-address=00:0C:42:05:4F:BD
max-station-count=2007 mode=station-pseudobridge mtu=1500 name=wlan1
000C42054FBD rate-set=default scan-list=default security-profile=default
ssid=ITISWIFI station-bridge-clone-mac=00:00:00:00:00:00
/interface wireless manual-tx-power-table
set AP comment=“” manual-tx-powers=“1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mb
ps:17,9Mbps:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:17,54Mbps:17
,HT20-1:0,HT20-2:0,HT20-3:0,HT20-4:0,HT20-5:0,HT20-6:0,HT20-7:0,HT20-8:0,H
T40-1:0,HT40-2:0,HT40-3:0,HT40-4:0,HT40-5:0,HT40-6:0,HT40-7:0,HT40-8:0”
set wlan1 comment=“” manual-tx-powers=“1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,
6Mbps:17,9Mbps:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:17,54Mbps
:17,HT20-1:0,HT20-2:0,HT20-3:0,HT20-4:0,HT20-5:0,HT20-6:0,HT20-7:0,HT20-8:
0,HT40-1:0,HT40-2:0,HT40-3:0,HT40-4:0,HT40-5:0,HT40-6:0,HT40-7:0,HT40-8:0”
/interface wireless nstreme
set AP comment=“” disable-csma=no enable-nstreme=no enable-polling=yes
framer-limit=3200 framer-policy=none
set wlan1 comment=“” disable-csma=no enable-nstreme=no enable-polling=yes
/ip hotspot profile
set default dns-name=“” hotspot-address=0.0.0.0 html-directory=hotspot
http-cookie-lifetime=3d http-proxy=0.0.0.0:0 login-by=cookie,http-chap
name=default rate-limit=“” smtp-server=0.0.0.0 split-user-domain=no
use-radius=no
/ip hotspot user profile
set default idle-timeout=none keepalive-timeout=2m name=default shared-users=
1 status-autorefresh=1m transparent-proxy=no
/ip ipsec proposal
set default auth-algorithms=sha1 disabled=no enc-algorithms=3des lifetime=30m
name=default pfs-group=modp1024
add name=dhcp_pool1 ranges=192.168.30.2-192.168.30.254
add address-pool=dhcp_pool1 authoritative=after-2sec-delay bootp-support=
static disabled=no interface=AP lease-time=3d name=dhcp1
/port
set 0 baud-rate=9600 data-bits=8 flow-control=hardware name=serial0 parity=
none stop-bits=1
/ppp profile
set default change-tcp-mss=yes comment=“” name=default only-one=default
use-compression=default use-encryption=default use-vj-compression=default
set default-encryption change-tcp-mss=yes comment=“” name=default-encryption
only-one=default use-compression=default use-encryption=yes
/interface pppoe-client
add ac-name=“” add-default-route=yes allow=pap,chap,mschap1,mschap2 comment=
“” dial-on-demand=no disabled=no interface=wlan1 max-mru=1480 max-mtu=
1480 mrru=disabled name=pppoe-out1 password=spain01 profile=default
service-name=“” use-peer-dns=no user=helen
/queue type
set default kind=pfifo name=default pfifo-limit=50
set ethernet-default kind=pfifo name=ethernet-default pfifo-limit=50
set wireless-default kind=sfq name=wireless-default sfq-allot=1514
sfq-perturb=5
set synchronous-default kind=red name=synchronous-default red-avg-packet=1000
red-burst=20 red-limit=60 red-max-threshold=50 red-min-threshold=10
set hotspot-default kind=sfq name=hotspot-default sfq-allot=1514 sfq-perturb=
5
set default-small kind=pfifo name=default-small pfifo-limit=10
/routing bgp instance
set default as=65530 client-to-client-reflection=yes comment=“” disabled=no
ignore-as-path-len=no name=default out-filter=“” redistribute-connected=
no redistribute-ospf=no redistribute-other-bgp=no redistribute-rip=no
redistribute-static=no router-id=0.0.0.0
/routing ospf area
add area-id=0.0.0.0 authentication=none disabled=no name=backbone type=
default
/snmp
set contact=“” enabled=no engine-boots=0 engine-id=“” location=“”
time-window=15 trap-sink=0.0.0.0 trap-version=1
/snmp community
set public address=0.0.0.0/0 authentication-password=“”
authentication-protocol=MD5 encryption-password=“” encryption-protocol=
DES name=public read-access=yes security=none write-access=no
/system logging action
set memory memory-lines=100 memory-stop-on-full=no name=memory target=memory
set disk disk-lines=100 disk-stop-on-full=no name=disk target=disk
set echo name=echo remember=yes target=echo
set remote name=remote remote=0.0.0.0:514 target=remote
/system routerboard settings
set baud-rate=115200 boot-delay=2s boot-device=nand-if-fail-then-ethernet
boot-protocol=bootp cpu-frequency=399MHz cpu-mode=power-save
enable-jumper-reset=yes enter-setup-on=any-key
/user group
add name=read policy=“local,telnet,ssh,reboot,read,test,winbox,password,web,sn
iff,!ftp,!write,!policy”
add name=write policy=“local,telnet,ssh,reboot,read,write,test,winbox,password
,web,sniff,!ftp,!policy”
add name=full policy=“local,telnet,ssh,ftp,reboot,read,write,policy,test,winbo
x,password,web,sniff”
/user
add address=0.0.0.0/0 comment=“system default user” disabled=no group=full
name=admin
/interface bridge settings
set use-ip-firewall=no use-ip-firewall-for-vlan=no
/interface ethernet mirror
set
/interface l2tp-server server
set authentication=pap,chap,mschap1,mschap2 default-profile=
default-encryption enabled=no max-mru=1460 max-mtu=1460 mrru=disabled
/interface ovpn-server server
set auth=sha1,md5 certificate=none cipher=blowfish128,aes128 default-profile=
default enabled=no keepalive-timeout=60 mac-address=FE:90:ED:E8:6F:7A
max-mtu=1500 mode=ip netmask=24 port=1194 require-client-certificate=no
/interface pptp-server server
set authentication=mschap1,mschap2 default-profile=default-encryption
enabled=no keepalive-timeout=30 max-mru=1460 max-mtu=1460 mrru=disabled
/interface wireless align
set active-mode=yes audio-max=-20 audio-min=-100 audio-monitor=
00:00:00:00:00:00 filter-mac=00:00:00:00:00:00 frame-size=300
frames-per-second=25 receive-all=no ssid-all=no
/interface wireless sniffer
set channel-time=200ms file-limit=10 file-name=“” memory-limit=10
multiple-channels=no only-headers=no receive-errors=no streaming-enabled=
no streaming-max-rate=0 streaming-server=0.0.0.0
/interface wireless snooper
set channel-time=200ms multiple-channels=yes receive-errors=no
/ip accounting
set account-local-traffic=no enabled=no threshold=256
/ip accounting web-access
set accessible-via-web=no address=0.0.0.0/0
add address=192.168.30.1/24 broadcast=192.168.30.255 comment=“” disabled=no
interface=AP network=192.168.30.0
/ip dhcp-client
add add-default-route=yes comment=“” default-route-distance=0 disabled=no
interface=wlan1 use-peer-dns=yes use-peer-ntp=yes
/ip dhcp-server config
set store-leases-disk=5m
add address=192.168.30.0/24 comment=“” dns-server=8.8.8.8,8.8.4.4 gateway=
192.168.30.1 netmask=24
set allow-remote-requests=no cache-max-ttl=1w cache-size=2048KiB
max-udp-packet-size=512 primary-dns=8.8.8.8 secondary-dns=8.8.4.4
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s
tcp-close-wait-timeout=10s tcp-established-timeout=1d
tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s
tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s tcp-syncookie=no
tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=10s
add action=masquerade chain=srcnat comment=“” disabled=no src-address=
192.168.30.0/24
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061
set pptp disabled=no
/ip hotspot service-port
/ip neighbor discovery
set ether1 discover=yes
set ether2 discover=yes
set ether3 discover=yes
set AP discover=no
set wlan1 discover=no
set pppoe-out1 discover=no
set bridge1 discover=yes
/ip proxy
set always-from-cache=no cache-administrator=webmaster cache-hit-dscp=4
cache-on-disk=no enabled=no max-cache-size=unlimited
max-client-connections=600 max-fresh-time=3d max-server-connections=600
parent-proxy=0.0.0.0 parent-proxy-port=0 port=8080 serialize-connections=
no src-address=0.0.0.0
/ip service
set telnet address=0.0.0.0/0 disabled=no port=23
set ftp address=0.0.0.0/0 disabled=no port=21
set www address=0.0.0.0/0 disabled=no port=80
set ssh address=0.0.0.0/0 disabled=no port=22
set www-ssl address=0.0.0.0/0 certificate=none disabled=yes port=443
set api address=0.0.0.0/0 disabled=yes port=8728
set winbox address=0.0.0.0/0 disabled=no port=8291
/ip socks
set connection-idle-timeout=2m enabled=no max-connections=200 port=1080
/ip traffic-flow
set active-flow-timeout=30m cache-entries=4k enabled=no
inactive-flow-timeout=15s interfaces=all
/ip upnp
set allow-disable-external-interface=yes enabled=no show-dummy-rule=yes
/ppp aaa
set accounting=yes interim-update=0s use-radius=no
/queue interface
set ether1 queue=ethernet-default
set ether2 queue=ethernet-default
set ether3 queue=ethernet-default
set AP queue=wireless-default
set wlan1 queue=wireless-default
set pppoe-out1 queue=default
set bridge1 queue=default
/radius incoming
set accept=no port=3799
/routing mme
set bidirectional-timeout=2 gateway-class=none gateway-keepalive=1m
gateway-selection=no-gateway origination-interval=5s preferred-gateway=
0.0.0.0 timeout=1m ttl=50
/routing ospf
set distribute-default=never metric-bgp=20 metric-connected=20
metric-default=1 metric-rip=20 metric-static=20 mpls-te-area=unspecified
mpls-te-router-id=unspecified redistribute-bgp=no redistribute-connected=
no redistribute-rip=no redistribute-static=no router-id=0.0.0.0
/routing rip
set distribute-default=never garbage-timer=2m metric-bgp=1 metric-connected=1
metric-default=1 metric-ospf=1 metric-static=1 redistribute-bgp=no
redistribute-connected=no redistribute-ospf=no redistribute-static=no
timeout-timer=3m update-timer=30s
/store
add comment=“” disabled=no disk=system name=web-proxy1 type=web-proxy
/system clock manual
set dst-delta=+00:00 dst-end=“jan/01/1970 00:00:00” dst-start=
“jan/01/1970 00:00:00” time-zone=+00:00
/system console
add disabled=no port=serial0 term=vt102
/system health
set fan-mode=auto use-fan=main
/system identity
set name=MikroTik
/system logging
add action=memory disabled=no prefix=“” topics=info
add action=memory disabled=no prefix=“” topics=error
add action=memory disabled=no prefix=“” topics=warning
add action=echo disabled=no prefix=“” topics=critical
/system note
set note=“” show-at-login=yes
/system ntp client
set enabled=no mode=broadcast primary-ntp=81.184.154.182 secondary-ntp=
31.25.23.151
/system upgrade mirror
set check-interval=1d enabled=no primary-server=0.0.0.0 secondary-server=
0.0.0.0 user=“”
/system watchdog
set auto-send-supout=no automatic-supout=yes no-ping-delay=5m watch-address=
none watchdog-timer=yes
/tool bandwidth-server
set allocate-udp-ports-from=2000 authenticate=yes enabled=yes max-sessions=10
/tool e-mail
set from=<> server=0.0.0.0
/tool graphing
set store-every=5min
/tool mac-server
add disabled=no interface=all
/tool mac-server ping
set enabled=yes
/tool sniffer
set file-limit=10 file-name=“” filter-address1=0.0.0.0/0:0-65535
filter-address2=0.0.0.0/0:0-65535 filter-protocol=ip-only filter-stream=
yes interface=all memory-limit=10 only-headers=no streaming-enabled=no
/user aaa
set accounting=yes default-group=read interim-update=0s use-radius=no
