Hey,
I have three VLANs, MGMT, HOME and GUEST.
I can access HOME and GUEST from MGMT, but I can’t access GUEST from HOME, even with rejecting/dropping firewall rules off. And I don’t know what’s the reason. I moved my IoTs to GUEST to separate them, and I can’t access them in LAN.
My current config below:
[admin@RB760iGS] > export hide-sensitive
# aug/05/2019 16:57:48 by RouterOS 6.45.2
# software id = HJFI-YNP6
# model = RB760iGS
# serial number = A36A0A453B20
add name=BR1 protocol-mode=none vlan-filtering=yes
set [ find default-name=ether1 ] name=ether1-WAN-livebox
set [ find default-name=ether4 ] name=ether4-TRUNK-MR3020
set [ find default-name=ether5 ] advertise=100M-full,1000M-full name=ether5-TRUNK-RB951G
/interface vlan
add interface=BR1 name=GUEST_VLAN vlan-id=20
add interface=BR1 name=HOME_VLAN vlan-id=10
add interface=BR1 name=MANAGEMENT vlan-id=99
/caps-man security
add authentication-types=wpa2-psk encryption=aes-ccm name=home
add authentication-types=wpa2-psk encryption=aes-ccm name=guest
add authentication-types=wpa2-psk encryption=aes-ccm name=management
add name=WAN
add name=VLAN
add name=BASE
add name=LAN
/ip hotspot profile
/ip ipsec mode-config
add name=NordVPN responder=no src-address-list=HOME
/ip ipsec policy group
add name=NordVPN
/ip ipsec profile
add name=NordVPN
/ip ipsec peer
add address=ca458.nordvpn.com exchange-mode=ike2 name=NordVPN_CA458 profile=NordVPN
/ip ipsec proposal
add name=NordVPN pfs-group=none
add name=HOME ranges=192.168.5.100-192.168.5.254
add name=GUEST ranges=192.168.20.2-192.168.20.254
add name=MANAGEMENT ranges=192.168.0.10-192.168.0.254
add address-pool=GUEST disabled=no interface=GUEST_VLAN name=GUEST
add address-pool=MANAGEMENT disabled=no interface=MANAGEMENT name=MANAGEMENT
add address-pool=HOME disabled=no interface=HOME_VLAN lease-time=12h name=HOME
/dude
set data-directory=disk1 enabled=yes
add bridge=BR1 frame-types=admit-only-untagged-and-priority-tagged ingress-filtering=yes interface=ether2 pvid=10
add bridge=BR1 frame-types=admit-only-untagged-and-priority-tagged ingress-filtering=yes interface=ether3 pvid=10
add bridge=BR1 frame-types=admit-only-vlan-tagged ingress-filtering=yes interface=ether4-TRUNK-MR3020
add bridge=BR1 ingress-filtering=yes interface=ether5-TRUNK-RB951G
set discover-interface-list=BASE
/interface bridge vlan
add bridge=BR1 tagged=BR1,ether4-TRUNK-MR3020,ether5-TRUNK-RB951G untagged=ether2,ether3 vlan-ids=10
add bridge=BR1 tagged=BR1,ether4-TRUNK-MR3020,ether5-TRUNK-RB951G vlan-ids=99
add bridge=BR1 tagged=BR1,ether4-TRUNK-MR3020,ether5-TRUNK-RB951G vlan-ids=20
/interface detect-internet
set detect-interface-list=all
add interface=ether1-WAN-livebox list=WAN
add interface=MANAGEMENT list=VLAN
add interface=HOME_VLAN list=VLAN
add interface=GUEST_VLAN list=VLAN
add interface=MANAGEMENT list=BASE
add interface=HOME_VLAN list=LAN
add interface=MANAGEMENT list=LAN
add address=192.168.0.1/24 interface=MANAGEMENT network=192.168.0.0
add address=192.168.5.1/24 interface=HOME_VLAN network=192.168.5.0
add address=192.168.20.1/24 interface=GUEST_VLAN network=192.168.20.0
/ip dhcp-client
add dhcp-options=hostname,clientid disabled=no interface=ether1-WAN-livebox use-peer-dns=no use-peer-ntp=no
/ip dhcp-server lease
add address=192.168.0.0/24 dns-server=8.8.8.8,8.8.4.4 gateway=192.168.0.1
add address=192.168.5.0/24 dns-server=8.8.8.8,8.8.4.4 gateway=192.168.5.1 ntp-server=192.168.5.1
add address=192.168.20.0/24 dns-server=8.8.8.8,8.8.4.4 gateway=192.168.20.1 ntp-server=192.168.20.1
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip firewall address-list
add address=192.168.5.0/24 list=HOME
add action=drop chain=forward comment="Drop invalid" connection-state=invalid
add action=reject chain=forward comment="Reject HOME from GUEST" dst-address=192.168.5.0/24 reject-with=icmp-host-prohibited src-address=192.168.20.0/24
add action=reject chain=forward comment="Reject MGMT from GUEST" connection-state=new dst-address=192.168.0.0/24 reject-with=icmp-host-prohibited src-address=192.168.20.0/24
add action=reject chain=forward comment="Reject LIVEBOX from GUEST" dst-address=192.168.1.0/24 reject-with=icmp-host-prohibited src-address=192.168.20.0/24
add action=reject chain=forward comment="Reject MGMT from HOME" dst-address=192.168.0.0/24 reject-with=icmp-host-prohibited src-address=192.168.5.0/24
add action=accept chain=forward comment="Forward / Allow / Estabilished / ALL" connection-state=established
add action=accept chain=forward comment="Forward / Allow / Related / ALL" connection-state=related
add action=accept chain=forward comment="Forward / Allow / New / ALL" connection-state=new
add action=drop chain=forward comment="Drop all other connections through the router"
add action=reject chain=input comment="Reject 5.1 from ALL" dst-address=192.168.5.1 dst-port=21,22,23,80,2000 protocol=tcp reject-with=icmp-host-prohibited
add action=reject chain=input comment="Reject 20.1 from ALL" dst-address=192.168.20.1 dst-port=21,22,23,80,2000 protocol=tcp reject-with=icmp-admin-prohibited src-address=192.168.20.0/24
add action=reject chain=input comment="Reject 0.1 from 5.0" dst-address=192.168.0.1 reject-with=icmp-host-prohibited src-address=192.168.5.0/24
add action=reject chain=input comment="Reject 0.1 from 20.0" dst-address=192.168.0.1 reject-with=icmp-host-prohibited src-address=192.168.20.0/24
add action=accept chain=input comment="Allow everything from the LAN interface to the router"
add action=accept chain=input comment="Allow established connections to the router, these are OK because we aren't allowing new connections" connection-state=established
add action=accept chain=input comment="Allow related connections to the router, these are OK because we aren't allowing new connections" connection-state=related
add action=drop chain=input comment="Drop everything else to the router" disabled=yes
add action=masquerade chain=srcnat out-interface=ether1-WAN-livebox src-address=192.168.0.0/24
add action=masquerade chain=srcnat out-interface=ether1-WAN-livebox src-address=192.168.5.0/24
add action=masquerade chain=srcnat out-interface=ether1-WAN-livebox src-address=192.168.20.0/24
/ip ipsec identity
add auth-method=eap certificate="" eap-methods=eap-mschapv2 generate-policy=port-strict mode-config=NordVPN peer=NordVPN_CA458 policy-template-group=NordVPN username=\
sliwma@
/ip ipsec policy
add dst-address=0.0.0.0/0 group=NordVPN proposal=NordVPN src-address=0.0.0.0/0 template=yes
add distance=1 gateway=192.168.1.1
/snmp
set enabled=yes
/system clock
set time-zone-name=Europe/Warsaw
/system identity
set name=RB760iGS
/system ntp client
set enabled=yes primary-ntp=193.110.137.171 secondary-ntp=158.75.5.245
/system ntp server
set enabled=yes manycast=no multicast=yes
/tool graphing interface
add
/tool graphing queue
add
/tool graphing resource
add
/tool mac-server
set allowed-interface-list=BASE
/tool mac-server mac-winbox
