I would ask your help in routing between vlans on RB4011iGS+5HacQ2HnD.
VLAN filtering is enabled and working, but I can’t open connection from vlan100 to vlan200. I just assume the routing is missing, but I’m not sure what should be added.
eth1: WAN
eth2 (vlan100): hap ac2 1 (caps)
eth3 (vlan100): hap ac2 2 (caps)
eth4 (vlan100): client device
eth5 (vlan100): client device
eth6 (vlan100): client device
eth7: empty
eth8 (vlan10): admin access
eth9 (vlan200): poe switch for survilliance cameras
eth10: empty
wlan1 (vlan100)
wlan2 (vlan100)
Networks:
192.168.10.0/24 - vlan10 (admin)
192.168.90.0/24 - vpn
192.168.95.0/24 - vlan100 (clients)
192.168.200.0/24 - vlan200 (surveillance)
This model has two separate switches inside (switch1: eth1-5, switch2: eth6-10) and as I found on wiki, these switches don’t support vlan table feature, so I’m lost how to continue with this..
I also tried debugging with packet sniffer on ether9, but no response from device in vlan200.
I’m sure you will ask for the full config, so here it is:
# 2024-10-29 09:01:09 by RouterOS 7.16
# software id = PT47-7AMD
# model = RB4011iGS+5HacQ2HnD
/caps-man channel
add band=2ghz-b/g/n control-channel-width=20mhz frequency=2412 name=ch24
add band=5ghz-onlyn name=ch5
add name=bridge vlan-filtering=yes
/interface wireless
# managed by CAPsMAN
# channel: 5300/20-Ce/an/DP(17dBm), SSID: Hidden Network, CAPsMAN forwarding
set [ find default-name=wlan2 ] country=MY_COUNTRY mode=ap-bridge ssid= MikroTik_5G
/interface wireguard
add listen-port=9980 mtu=1420 name=wireguard1
/interface vlan
add interface=bridge name=vlan10 vlan-id=10
add interface=bridge name=vlan100 vlan-id=100
add interface=bridge name=vlan200 vlan-id=200
/caps-man datapath
add bridge=bridge client-to-client-forwarding=yes name=datapath1 vlan-id=100 vlan-mode=use-tag
/caps-man security
add authentication-types=wpa-psk encryption=aes-ccm name=sec1
/caps-man configuration
add channel=ch24 country=MY_COUNTRY datapath=datapath1 distance=indoors installation=indoor mode=ap name=cfg_24 security=sec1 ssid= "Hidden Network"
add channel=ch5 channel.band=5ghz-n/ac .control-channel-width=20mhz .frequency=5240 country=MY_COUNTRY datapath=datapath1 distance=indoors installation=indoor mode=ap name=cfg_5 rates.supported="" security=sec1 ssid="Hidden Network"
/caps-man interface
add configuration=cfg_24 disabled=no l2mtu=1600 mac-address=xx:xx:xx:xx:xx:xx master-interface=none name=cap1 radio-mac=xx:xx:xx:xx:xx:xx radio-name=xx
add channel=ch5 channel.frequency=5300 configuration=cfg_5 configuration.installation=any disabled=no l2mtu=1600 mac-address= xx:xx:xx:xx:xx:xx master-interface=none name=cap2 radio-mac= xx:xx:xx:xx:xx:xx radio-name=xx
add channel.frequency=2422 configuration=cfg_24 disabled=no l2mtu=1600 mac-address=xx:xx:xx:xx:xx:xx master-interface=none name=cap3 radio-mac= xx:xx:xx:xx:xx:xx radio-name=xx
add channel=ch5 channel.frequency=5180 configuration=cfg_5 disabled=no l2mtu= 1600 mac-address=xx:xx:xx:xx:xx:xx master-interface=none mtu=1500 name= cap4 radio-mac=xx:xx:xx:xx:xx:xx radio-name=xx
add channel.frequency=2432 configuration=cfg_24 disabled=no l2mtu=1600 mac-address=xx:xx:xx:xx:xx:xx master-interface=none name=cap5 radio-mac= xx:xx:xx:xx:xx:xx radio-name=xx
add channel=ch5 channel.frequency=5240 configuration=cfg_5 disabled=no l2mtu= 1600 mac-address=xx:xx:xx:xx:xx:xx master-interface=none name=cap6 radio-mac=xx:xx:xx:xx:xx:xx radio-name=xx
add name=LAN
/interface wifi security
add authentication-types=wpa2-psk disabled=no name=sec
add authentication-types=wpa2-psk mode=dynamic-keys name=profile1 supplicant-identity=""
/interface wireless
# channel: 2412/20-Ce/gn(17dBm), SSID: Hidden Network, CAPsMAN forwarding
set [ find default-name=wlan1 ] country=MY_COUNTRY installation=indoor mode= ap-bridge security-profile=profile1 ssid=MikroTik
add name=dhcp_pool0 ranges=192.168.95.30-192.168.95.254
add name=dhcp_pool1 ranges=192.168.10.2-192.168.10.254
add name=dhcp_pool2 ranges=192.168.200.2-192.168.200.254
add address-pool=dhcp_pool0 interface=vlan100 name=dhcp1
add address-pool=dhcp_pool1 interface=vlan10 name=dhcp_vlan10
add address-pool=dhcp_pool2 interface=vlan200 name=dhcp_vlan200
/port
set 0 name=serial0
set 1 name=serial1
/caps-man manager
set enabled=yes
/caps-man provisioning
add action=create-dynamic-enabled master-configuration=cfg_24 radio-mac= xx:xx:xx:xx:xx:xx
add bridge=bridge interface=ether2 pvid=100
add bridge=bridge interface=ether3 pvid=100
add bridge=bridge interface=ether4 pvid=100
add bridge=bridge interface=ether5 pvid=100
add bridge=bridge interface=ether8 pvid=10
add bridge=bridge interface=ether9 pvid=200
add bridge=bridge interface=wlan1
add bridge=bridge interface=wlan2
add bridge=bridge interface=ether6 pvid=100
/interface bridge vlan
add bridge=bridge untagged=ether8 vlan-ids=10
add bridge=bridge tagged=bridge untagged=ether4,ether5,ether3,ether2,ether6 vlan-ids=100
add bridge=bridge tagged=ether9,bridge vlan-ids=200
add interface=bridge list=LAN
add interface=ether8 list=LAN
/interface wireless cap
set caps-man-addresses=127.0.0.1 enabled=yes interfaces=wlan1,wlan2
add address=192.168.95.1/24 interface=vlan100 network=192.168.95.0
add address=192.168.200.1/24 interface=vlan200 network=192.168.200.0
add address=192.168.10.1/24 interface=vlan10 network=192.168.10.0
add address=192.168.90.1/24 interface=wireguard1 network=192.168.90.0
/ip dhcp-client
add interface=ether1
/ip dhcp-server lease
add address=192.168.95.99 client-id=1:xx:xx:xx:xx:xx:xx mac-address= xx:xx:xx:xx:xx:xx server=dhcp1
add address=192.168.200.248 client-id=1:xx:xx:xx:xx:xx:xx mac-address= xx:xx:xx:xx:xx:xx server=dhcp_vlan200
add address=192.168.10.0/24 dns-server=192.168.95.3,192.168.95.33 gateway= 192.168.10.1
add address=192.168.95.0/24 dns-server=192.168.95.3,192.168.95.33 gateway= 192.168.95.1
add address=192.168.200.0/24 dns-server=192.168.95.3,192.168.95.33 gateway= 192.168.200.1
/ip firewall address-list
add address=192.168.95.0/24 list=admin_list
add address=192.168.10.0/24 list=admin_list
add address=0.0.0.0/8 comment=RFC6890 list=not_in_internet
add address=172.16.0.0/12 comment=RFC6890 list=not_in_internet
add address=192.168.0.0/16 comment=RFC6890 list=not_in_internet
add address=10.0.0.0/8 comment=RFC6890 list=not_in_internet
add address=169.254.0.0/16 comment=RFC6890 list=not_in_internet
add address=127.0.0.0/8 comment=RFC6890 list=not_in_internet
add address=224.0.0.0/4 comment=Multicast list=not_in_internet
add address=198.18.0.0/15 comment=RFC6890 list=not_in_internet
add address=192.0.0.0/24 comment=RFC6890 list=not_in_internet
add address=192.0.2.0/24 comment=RFC6890 list=not_in_internet
add address=198.51.100.0/24 comment=RFC6890 list=not_in_internet
add address=203.0.113.0/24 comment=RFC6890 list=not_in_internet
add address=100.64.0.0/10 comment=RFC6890 list=not_in_internet
add address=240.0.0.0/4 comment=RFC6890 list=not_in_internet
add address=192.88.99.0/24 comment="6to4 relay Anycast [RFC 3068]" list= not_in_internet
add address=192.168.95.0/24 list=LAN_network
add address=192.168.10.0/24 list=LAN_network
add address=10.15.0.0/16 list=SW_Server
add address=192.168.8.0/24 list=SW_Server
add address=10.8.0.0/16 list=SW_Server
add address=192.168.68.0/24 list=SW_Server
add address=172.28.249.0/24 list=SW_Server
add address=172.28.1.0/24 list=SW_Server
add address=192.168.4.0/24 list=SW_Server
add action=fasttrack-connection chain=forward comment= "fast-track for established,related" connection-state=established,related hw-offload=yes
add action=accept chain=input dst-port=8291,80 protocol=tcp src-address-list= admin_list
add action=accept chain=input comment="Accept ICMP" in-interface=ether1 protocol=icmp
add action=accept chain=forward comment="Established, Related" connection-state=established,related
add action=accept chain=forward dst-address-list=LAN_network src-address-list=LAN_network
add action=accept chain=forward comment=vlan100_to_vlan200 in-interface= vlan100 log-prefix=vlan100_to_vlan200 out-interface=vlan200
add action=accept chain=forward comment=vlan200_to_vlan200 connection-state= "" in-interface=vlan200 log-prefix=vlan200_to_bridge out-interface= vlan100
add action=accept chain=input comment="Wireguard allow" dst-port=9980 protocol=udp
add action=accept chain=forward comment="SW allow" dst-address-list=SW_Server src-mac-address=xx:xx:xx:xx:xx:xx
add action=drop chain=forward comment="Drop from vlan200 to internet" log=yes log-prefix=Drop_from_vlan200 out-interface=ether1 src-address= 192.168.200.0/24
add action=drop chain=input comment="block everything else - input_drop" in-interface=ether1 log-prefix=input_drop
add action=drop chain=forward comment="Drop invalid forward" connection-state=invalid
add action=drop chain=forward comment= "drop access to clients behind NAT from WAN" connection-nat-state=!dstnat connection-state=new in-interface=ether1
add action=drop chain=forward comment= "Drop tries to reach not public addresses from LAN - !public_from_LAN" dst-address-list=not_in_internet in-interface=bridge log=yes log-prefix= !public_from_LAN out-interface=!bridge
add action=drop chain=forward comment= "Drop incoming packets that are not NAT`ted - !NAT" connection-nat-state= !dstnat connection-state=new in-interface=ether1 log=yes log-prefix=!NAT
add action=drop chain=forward comment= "Drop incoming from internet which is not public IP - !public" in-interface=ether1 log=yes log-prefix=!public src-address-list= not_in_internet
add action=drop chain=forward comment= "Drop packets from LAN that do not have LAN IP - LAN_!LAN" in-interface= bridge log=yes log-prefix=LAN_!LAN src-address-list=!LAN_network
add action=masquerade chain=srcnat src-address=192.168.90.0/24
add action=masquerade chain=srcnat src-address=192.168.10.0/24
add action=masquerade chain=srcnat src-address=192.168.200.0/24
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh port=2200
set api disabled=yes
set winbox address=192.168.95.0/24,192.168.10.0/24
/system clock
set time-zone-autodetect=no time-zone-name=Europe/MY_CITY
/system identity
set name=MikroTik_4011
/system note
set show-at-login=no
/tool graphing interface
add allow-address=192.168.95.0/24 interface=ether1
/tool mac-server
/tool sniffer
set file-name=sniffer_eth9 filter-interface=ether9 memory-limit=1024KiB
