I have a canon printer/scanner in a different subnet that my laptop does.
Discovering the printer works, thanks to bonjour frames being relayed by avahi reflector.
However scanning doesn’t work and I suspect canon’s BJNP protocol and their broadcasted frames may be guilty for that.
Tcpdump / wireshark show me frames being sent to 10.2.0.255 and 224.0.0.1 port 8612 (Info: Canon BJNP, Scanner Command: Discover).
Protocols in frame: eth:ethertype:ip:udp:bjnp
Any chance I can relay these frames to the other VLAN/subnet ?
Thank you !
Edit:
I feel mangle/nat can help me, so I have a passthrough mangle rule increasing TTL, another passthrough one marking packet.
Then my idea was to output / echo these marked packets through the other interface’s vlan or so using either NAT or a default route but none will do.
Have you found a solution to this? I’m thinking of switching from EdgeRouter to MikroTik (I need a rackmout router and the Ubiquiti ones are far too expensive), but broadcast relay (for selected UDP ports) is a feature I require.
