OKNET
July 8, 2016, 9:03am
1
I want to choose a particular WAN interface to be used for calls to particular destination ports in internet.
In a rule like :
chain=prerouting action=mark-routing new-routing-mark=to_WAN3 protocol=tcp dst-port=8888
shoud I specify addresses not belong to my lan subnet ? i.e. add **dst-address=!192.168.1.0/24 ** (my LAN)
Thank you
That would work - you could also exempt your local networks from all policy routing with a route rule:
/ip route rule add dst=192.168.0.0/16 action=lookup-only-in-table table=main
OKNET
July 14, 2016, 12:34pm
3
I mean, the rule
is it processed also when a packet comes from a LAN machine to a LAN machine (so connection fails because routed to WAN3) ??
I have just checked LAN to LAN connection on port 8888 works despite that mangle rule exists, any thought ??
savage
July 14, 2016, 1:08pm
4
If your definition of LAN to LAN is two hosts on the same subnet, then no, the rule won’t touch that traffic. The traffic never even makes it to the router.
