After upgrade, no routing filter will be apply, any idea ?
I have the same problem with outgoing routes http://forum.mikrotik.com/t/routing-test-2-9-28-ospf-out-chain-problem/8402/1
Some mail sent to support, but no reply at the moment…
here it looks like that only when the box is starting the filters dont work
when the box is up allready an then you add som ip that schoudl be bloked by the filter it works
but wehn i reboot the box all the unwanted ips are announced athe the first ospf sturtup ;-((
Upgradated to 2.9.30, routing filter for ospf-out doesn’t still work !!!
Yes, it doesn’t work for us too. Some fix for it will be very helpful.
Will it be fixed in 2.9.31 please ???
