Routing Filter via Winbox
I can’t move filter rule via winbox, how can I move filter role in RouterOS 3?
Best Regards
Jakub
are you sure that you cannot move them (drag and drop)?
i have no problems with doing that
Hello, I work with Jakub and I confirm that we can’t move rules in rc1 - but only in routing filters. Rules in firewall filter, nat, mangle can be drag’n’dropped without problems.
Regards,
Andrzej
there are no difference in rule order, because first rules applied will be most specific ones.
order in rules will not change that.
Hello, and if we need to DISCARD some specific route and then ALLOW more general one then still order doesn’t matter?.. I think it’s as important as in packet filter…
Regards,
Andrzej
Just use command “move” in the CLI interface
Thanks Macgaiver, we do use “move”, we just wanted to report shortcoming of 3.0rc1.
Regards,
Andrzej
that will and should be in winbox… waiting for devs to act :slight_smile:
Funny this is back again in 6.10 mipsbe on a rb2011
What is your filter order? In order to move filter rules they have to be orderder by number.
