Routing filters with BGP in version 7.14.1 CHR not working . I tried different protocols and route entries are still imported into route tables.
Here are example of BGP
[admin@BL-RT-1] /routing/bgp> connection/print detail
Flags: D - dynamic, X - disabled, I - inactive
0 name="bgp-peer-4"
remote.address=172.30.100.4 .as=65635
local.address=172.30.100.5 .role=ibgp
connect=yes listen=yes routing-table=C-L2-DCI vrf=C-L2-DCI router-id=172.30.100.5 templates=BL2PE as=65635
address-families=ip use-bfd=yes
output.redistribute=connected .no-client-to-client-reflection=yes
input.filter=ISIS-32
[admin@BL-RT-1] /routing/bgp> /routing/filter/
chain community-large-list num-list select-rule test-as-path-regexp
community-ext-list community-list rule export
[admin@BL-RT-1] /routing/bgp> /routing/filter/rule/print
Flags: X - disabled, I - inactive
0 ;;; We not accepting subnets for underlay
chain=ISIS-32 rule="if ( dst-len==32 ) {accept; } else {reject; }"
[admin@BL-RT-1] /routing/bgp> /ip/route/print
Flags: D - DYNAMIC; I - INACTIVE, A - ACTIVE; c - CONNECT, b - BGP, d - DHCP
Columns: DST-ADDRESS, GATEWAY, DISTANCE
DST-ADDRESS GATEWAY DISTANCE
DAd 0.0.0.0/0 10.41.100.1 1
DAc 10.41.100.0/24 MGMT-V313-eth4 0
DAc 172.25.100.5/32 loop0@C-L2-DCI 0
DAb 172.25.100.6/32 172.30.100.4@C-L2-DCI 200
DIb 172.30.100.0/28 172.30.100.4@C-L2-DCI 200
DAc 172.30.100.0/28 D-L2-br0@C-L2-DCI 0
