Routing has gone nuts in in 2.9.43
hi guys,
I don’t understand why mikrotik routerOS is creating stupid routing table for disabled interface and none existing addressess!
this how it looks:
interfaces:
[admin@PersiaRestaurant] > /inter print
Flags: X - disabled, D - dynamic, R - running
 #    NAME                                                            TYPE             RX-RATE    TX-RATE    MTU
 0  R WAN1                                                            ether            0          0          1500
 1  R WAN2                                                            ether            0          0          1500
 2 X  port4                                                           ether            0          0          1500
 3 X  port3                                                           ether            0          0          1500
 4 X  port2                                                           ether            0          0          1500
 5 X  WAN3_LAN                                                        ether            0          0          1500
 6  R LAN                                                             ether            0          0          1500
IP Addressess
[admin@PersiaRestaurant] > /ip address print
 #   ADDRESS            NETWORK         BROADCAST       INTERFACE
 0   ;;; LAN
     10.1.1.1/24        10.1.1.0        10.1.1.255      LAN
 1   ;;; tbbh - 3325 2mb (1024)
     211.24.139.114/29  211.24.139.112  211.24.139.119  WAN1
 2 X ;;; telekom 1mb
     192.168.0.1/24     192.168.0.0     192.168.0.255   WAN1
 3   ;;; tbbh - 2358 2mb (512)
     211.24.149.43/29   211.24.149.40   211.24.149.47   WAN2
Routes
[admin@PersiaRestaurant] > /ip route print
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf,
 #      DST-ADDRESS        PREF-SRC        G GATEWAY         DISTANCE INTERFACE
 0 A S  ;;; 211.24.149.41
        0.0.0.0/0          211.24.149.43   r 211.24.149.41   1        WAN2
 1 A S  ;;; Default Gateway
        0.0.0.0/0                          r 211.24.139.113  1        WAN1
 2 A S  ;;; 211.24.149.139.113
        0.0.0.0/0          211.24.139.114  r 10.1.1.1        1        LAN
 3 ADC  10.1.1.0/24        10.1.1.1                          0        LAN
 4   S  ;;; www.potent-axis.com through streamyx
        202.75.36.163/32   192.168.0.1     u 192.168.0.250   1
 5   S  ;;; Telekom DNS
        202.188.0.133/32   192.168.0.1     u 192.168.0.250   1
 6   S  ;;; Telekom DNS
        202.188.1.5/32     192.168.0.1     u 192.168.0.250   1
 7 A S  ;;; Time DNS
        203.12.16.85/32    211.24.149.43   r 211.24.149.41   1        WAN2
 8 A S  ;;; Time DNS
        203.121.16.85/32   211.24.149.43   r 211.24.149.41   1        WAN2
 9 ADC  211.24.139.112/29  10.1.1.1                          0        LAN
10 ADC  211.24.149.40/29   10.1.2.1                          0        WAN3_LAN
write to support with supout.rif and clarification how you got it do do this :slight_smile:
