Routing in Hotspot
Original Config:
5 Access Points and 1 Hotspot.
1 DHCP server and everything in a Bridge.
New Config:
Network is routed and each access point has a different network and DHCP Server.
Problem with New Config:
Users jump around access points quite a bit and therefore they will get a new IP; but that will kick them out of the hotspot.
Any ideas on how to configure the hotspot so the users will not have to keep loggin in.
IP translation is turned off on the hotspot currently.
You can use cookies and extend the lifetime of the cookies as you desire.
e.g /ip hotspot profile set 0 login=cookie,http-chap http-cookie-lifetime=365d
