I cannot find a routing table that works for accessing via winbox every single host in each lan from my office network.
As you can see there are multiple NAT layers.
Below network map:
Below network map:
Hi
which network you you have defined between
These routes are added automatically for you when you define the local ip. Then just access “left” & “right” 3011’s by ip’s on these networks.µ
=> that’s just for RB’s
To access the whole network:
Ex
static on central 3011
“75” go left
“19” go left
“40” go left
“76” go right
“18” go right
“20” go right
similar for “left” & “right” 3011
as the network is not so big, you can exclude destinations toward your OFFICE LAN from all the NATS and also write a few static route on each router for the OFFICE LAN
RB3011 FROM MY OFFICE LAN:
0 192.168.1.62/24 199.168.1.0 bridge2 -->INTERNET GATEWAY
1 192.168.15.1/24 192.168.15.0 bridge1 -->OFFICE LAN
2 192.168.19.150/24 192.168.19.0 ether3 -->RB3011 192.168.19.1
3 192.168.18.150/24 192.168.18.0 ether9 -->RB3011 192.168.18.1
ROUTES:
0 A 0.0.0.0/0 192.168.1.1 STATIC
A S DST-ADD 192.168.75.0/24 GW 192.168.19.1 STATIC
A S DST-ADD 192.168.76.0/24 GW 192.168.18.1 STATIC
ADC 192.168.15.0/24 192.168.15.1 bridge1 DYNAMIC
ADC 192.168.18.0/24 192.168.18.150 ether9 DYNAMIC
ADC 192.168.19.0/24 192.168.19.150 ether3 DYNAMIC
With this config Ican only ping devices within each lan but no winbox access.
Your central RB, is directly connected to both RB “left” & “right”. There are “connected” routes defined for them with distance 0.
You SHOULD be able to connect to them, if you can’t check firewall settings.
no firewall enabled in each rb3011
Short answer, get rid of all the natting and run a routing protocol, then you don’t have to worry at all. It would all “just be connected”.
I’m probably missing the reason why you’re using so many nats though.
Few other things to check:
